Ga door naar hoofdinhoud
Jura Impressa C E F models coffee dispenser replacement
Wat je nodig hebt
  1. Jura Impressa C E F models coffee dispenser replacement, Jura Impressa Type C E F opening procedure: stap 1, afbeelding 1 van 1
    • The instructions are suitable for nearly every model of Jura and similar ones e.g. AEG and Krups.
    • Unplug!
    • Remove the water reservoir.
  2. Jura Impressa C E F models coffee dispenser replacement: stap 2, afbeelding 1 van 3 Jura Impressa C E F models coffee dispenser replacement: stap 2, afbeelding 2 van 3 Jura Impressa C E F models coffee dispenser replacement: stap 2, afbeelding 3 van 3
    • On the rear side is an obstacle: four "oval head screws" looking like rivets. You can remove them using a special oval drive bit. They are sold at iFixit with the tool kits as well as some Jura suppliers or somewhere in the internet. Jura wants to keep us out of our own machines!
    • Using an oval head bit you can screw them out. If you haven´t got one you can carefully use pliers. It is a good idea to later change the screws for normal ones.
    • Beneath both top side covers are two Torx T15 screws. Remove those. Now lift off the whole top cover. Sometimes it jams and you have to use a bit of force.
    • The side covers must be pushed backwards by about 1 cm. Sometimes this is a little bit difficult to move. If necessary, wedge a plastic opening tool into the gap between the side covers and the front panel. The rear cover can be easily removed.
  3. Jura Impressa C E F models coffee dispenser replacement, Coffee dispenser: stap 3, afbeelding 1 van 2 Jura Impressa C E F models coffee dispenser replacement, Coffee dispenser: stap 3, afbeelding 2 van 2
    • Unscrew the two T10 Torx screws at the bottom of the front panel.
  4. Jura Impressa C E F models coffee dispenser replacement: stap 4, afbeelding 1 van 1
    • Unscrew the T15 Torx screw on the right.
  5. Jura Impressa C E F models coffee dispenser replacement: stap 5, afbeelding 1 van 1
    • Remove the T15 Torx screw from the left side as well
    • The front cover is still connected on the bottom by two bayonet like fasteners. Lift the machine slightly up and release the fasteners and remove the front cover
    • Insert translation here
    • The front is still connected to the rest of the machine with some wiring and the steam hose. To remove the steam hose, simple pull the hose clamp off. Depending on the repair the cable can either stay connected or can be separated from the front by the connector.
  6. Jura Impressa C E F models coffee dispenser replacement: stap 6, afbeelding 1 van 1
    • Open the front cover as far as possible to the sides.
    • Loosen the hose clamp on the steam hose and pull the hose off.
    • Pull the thick cable off the clamps on the front cover.
  7. Jura Impressa C E F models coffee dispenser replacement: stap 7, afbeelding 1 van 3 Jura Impressa C E F models coffee dispenser replacement: stap 7, afbeelding 2 van 3 Jura Impressa C E F models coffee dispenser replacement: stap 7, afbeelding 3 van 3
    • Remove the four T10 Torx screws that hold the coffee spout to the housing.
    • In case this has not yet been done, remove the inlet funnel. It is connect by two T10 Torx screws. (This picture shows it already removed)
    • These are the magnet that hold two metal sliding plates in place. Do not lose those.
    • With a little bit of force remove the holder from the coffee spout.
  8. Jura Impressa C E F models coffee dispenser replacement: stap 8, afbeelding 1 van 2 Jura Impressa C E F models coffee dispenser replacement: stap 8, afbeelding 2 van 2
    • To the coffee spout is a decorative panel attached. Slide it of the spout by the tab.
    • On the inside of the spout is still distribution nozzle. Remove this by removing the tab on the top side.
    • Clean the coffee spout thoroughly or replace it if needed
  9. Jura Impressa C E F models coffee dispenser replacement: stap 9, afbeelding 1 van 2 Jura Impressa C E F models coffee dispenser replacement: stap 9, afbeelding 2 van 2
    • Advice for the assembly:
    • The coffee spout can be moved up and down, but must also remain in any position. As a brake, two sliding plates are held in place by magnets on the back of the bracket. Be careful not to lose these magnets.
    • There are four pins on the back of the coffee spout. Insert these into the corresponding holes in the sliding plates. It is a bit tricky to install and screw the holder and the coffee spout at the same time.
    • Check whether the spout can be moved against slight resistance and whether it remains in any position.
Conclusie
Follow the steps in reverse order to reassemble your coffee machine
7 andere personen hebben deze handleiding voltooid.
Met dank aan deze vertalers:
de en
100%
Deze vertalers helpen ons de wereld te repareren! Wil je bijdragen?
Begin met vertalen ›
VauWeh
165.841 Reputatie
212 handleidingen geschreven
4 opmerkingen
Tipp: Beim Öffnen Staubsauger und Pinsel parat haben, damit man die vielen kleinen Bohnen aus den ganzen Rillen saugen kann.
nepumax - Antwoord
Danke,
war sehr hilfreich und hat zum Erfolg geführt!
Kurt Bühler - Antwoord
*******Auf der Rückseite des Kaffeeauslaufs befinden sich vier Stifte. Setze diese in die entsprechenden Löcher in den Gleitblechen ein. Es ist etwas knifflig, den Halter und den Kaffeeauslauf gleichzeitig einzubauen und zu verschrauben.*******
Wenn man die Magnete entfernt hat braucht man nicht alles gleichzeitig zu machen. Zuerst Auslauf, dann denn Halter und dann die zwei Magnete.
So klappt es auch einfacher
Paul Hendriks - Antwoord
Gute Anleitung, das lösen der Arretierung der silbernen Blende könnte etwas detaillierter beschrieben werden.
Günter Bertsch - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 34
Afgelopen 7 dagen: 184
Afgelopen 30 dagen: 757
Altijd: 15,836
