Inleiding
If water is dripping under the floor panel in the front right area, you need to investigate where it is coming from. Check the water heaters, ceramic valve, exhaust valve and their hoses. If everything is dry, the somewhat inconspicuous heat exchanger could also be leaking at the bottom. It is made of light metal, its lid has only one screw in the middle. The lid can warp and is difficult to seal. A new heat exchanger solves the problem. To get better access, the ceramic valve must first be loosened, its connections can remain. The outlet valve should also be removed, the connections can remain.
Wat je nodig hebt
Remove the water tank and the drip tray. Remove all coffee beans from the storage container.
The motor for the drainage valve is located in the lower side of the unit near the center. It is fastened with three screws and connected with several flat plugs. In the picture, the ceramic valve has already been pushed off.
Here is the removed heat exchanger. You'll find it at the bottom behind the ceramic valve.
You should also detach the exhaust valve for better access. To do this, pull off the clip on the right-hand side.
Follow the steps in reversed order to disassemble your device
Één andere persoon heeft deze handleiding voltooid.
Met dank aan deze vertalers:
100%
oldturkey03 helpt ons de wereld te herstellen! Wil je bijdragen?
Begin met vertalen ›
