Ga door naar hoofdinhoud
Jumper Angelsounds JPD-100S Motherboard Replacement
Wat je nodig hebt
  1. Jumper Angelsounds JPD-100S Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 1
    • Access the battery compartment
    • Remove the battery compartment lid and set it aside.
    • Disconnect the battery and set it aside.
  2. Jumper Angelsounds JPD-100S Motherboard Replacement: stap 2, afbeelding 1 van 2 Jumper Angelsounds JPD-100S Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Puncture the sticker in the battery compartment with a spudger to access the screw beneath it.
  3. Jumper Angelsounds JPD-100S Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Remove the 7mm Phillips #1 screw from the battery compartment.
    • Place the screw in a secure place.
  4. Jumper Angelsounds JPD-100S Motherboard Replacement: stap 4, afbeelding 1 van 2 Jumper Angelsounds JPD-100S Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Begin prying open the device.
    • Insert a plastic opening tool into the side groove about 2cm from the pink plastic component and pry open one side of the device.
    • Once the side is separated, leave the opening tool inside to prevent the two sides from closing.
  5. Jumper Angelsounds JPD-100S Motherboard Replacement: stap 5, afbeelding 1 van 2 Jumper Angelsounds JPD-100S Motherboard Replacement: stap 5, afbeelding 2 van 2
    • Insert another plastic opening tool into the groove opposite to the side of the tool already inserted.
    • Create separation on that side until the white plastic component comes off entirely.
    • Place the white plastic component in a secure place.
  6. Jumper Angelsounds JPD-100S Motherboard Replacement: stap 6, afbeelding 1 van 1
    • With your hand, remove the pink component.
  7. Jumper Angelsounds JPD-100S Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Remove the 7mm Phillips #1 screw in the middle of the motherboard.
Eindstreep
Deron Rogers
271 Reputatie
2 handleidingen geschreven
USF Tampa, Team 6-1, Remmell Fall 2015 Lid van USF Tampa, Team 6-1, Remmell Fall 2015
USFT-REMMELL-F15S6G1
6 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 9
Altijd: 224
