Ga door naar hoofdinhoud
Jazz Digi-Stix JDC11 Viewer Replacement
Wat je nodig hebt
    1. Jazz Digi-Stix JDC11 Viewer Replacement, Battery: stap 1, afbeelding 1 van 2 Jazz Digi-Stix JDC11 Viewer Replacement, Battery: stap 1, afbeelding 2 van 2
      • Flip the device so that the bottom is facing upwards. Using thumb, push the tab on the bottom in the direction indicated by the arrow and then lift the unhinged part of the tab.
      Vraag FixBot
      Voeg opmerking toe
    2. Jazz Digi-Stix JDC11 Viewer Replacement: stap 2, afbeelding 1 van 1
      • Tilt device so that batteries slide out.
      Vraag FixBot
      Voeg opmerking toe
    1. Jazz Digi-Stix JDC11 Viewer Replacement, Viewer: stap 3, afbeelding 1 van 3 Jazz Digi-Stix JDC11 Viewer Replacement, Viewer: stap 3, afbeelding 2 van 3 Jazz Digi-Stix JDC11 Viewer Replacement, Viewer: stap 3, afbeelding 3 van 3
      • Carefully insert spudger into the seam on the top side of the device and tilt and twist the spudger to open the device. Work it around the device until the two case halves separate.
      • Before completely separating the two halves, grab the tab on the bottom of the device and pull the two halves of the case away from the hinged part of the tab so as not to break the plastic rods.
      • When separating the two halves of the case, be careful not to disconnect the various wires attached to the motherboard and the battery case.
      Vraag FixBot
      Voeg opmerking toe
    2. Jazz Digi-Stix JDC11 Viewer Replacement: stap 4, afbeelding 1 van 3 Jazz Digi-Stix JDC11 Viewer Replacement: stap 4, afbeelding 2 van 3 Jazz Digi-Stix JDC11 Viewer Replacement: stap 4, afbeelding 3 van 3
      • Pull the viewer free from the left hand side of the case.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Katelyn Fry
1 Reputatie
7 handleidingen geschreven
Clemson, Team 12-3, Benson Spring 2013 Lid van Clemson, Team 12-3, Benson Spring 2013
CLEM-BENSON-S13S12G3
3 Leden
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 24
Altijd: 607
