Ga door naar hoofdinhoud
Jawbone Big Jambox Micro USB Port Replacement
Wat je nodig hebt
    1. Jawbone Big Jambox Micro USB Port Replacement, Outer Case: stap 1, afbeelding 1 van 1
      • Remove both end caps by putting a plastic opening tool in the center of the seam. Work around the edges to pry the end caps off completely.
      • Due to interior clips holding the end caps in place, use caution when applying force.
      Vraag FixBot
      Voeg opmerking toe
    2. Jawbone Big Jambox Micro USB Port Replacement: stap 2, afbeelding 1 van 3 Jawbone Big Jambox Micro USB Port Replacement: stap 2, afbeelding 2 van 3 Jawbone Big Jambox Micro USB Port Replacement: stap 2, afbeelding 3 van 3
      • Turn the Jambox upside down. Peel the indicated rubber tabs off, using a plastic opening tool if necessary.
      • You may want to only take the tabs half way off to avoid re-gluing when reassembling.
      • Remove the three T6, 7.0 mm screws under each rubber tab.
      • Because the screws are a different length, set the screws aside.
      Vraag FixBot
      Voeg opmerking toe
    3. Jawbone Big Jambox Micro USB Port Replacement: stap 3, afbeelding 1 van 3 Jawbone Big Jambox Micro USB Port Replacement: stap 3, afbeelding 2 van 3 Jawbone Big Jambox Micro USB Port Replacement: stap 3, afbeelding 3 van 3
      • With the Jawbone logo facing towards you and with correct orientation, place the Jambox with the left end cap facing upward.
      • Unscrew indicated T6 9.7 mm screws.
      • Gently loosen the tabs from their anchor points so the bottom may be removed.
      • Flip the Jambox so the other end cap is facing up. The USB cable is on this side (metal grounding clip, indicated in orange). Repeat the above two steps.
      Vraag FixBot
      Voeg opmerking toe
    4. Jawbone Big Jambox Micro USB Port Replacement: stap 4, afbeelding 1 van 1
      • Pry up the bottom panel by lifting from the device.
      • Pull the bottom up. This may take a bit of force as the bottom is glued to device.
      • Once removed, the battery will now be visible.
      Vraag FixBot
      Voeg opmerking toe
    5. Jawbone Big Jambox Micro USB Port Replacement: stap 5, afbeelding 1 van 2 Jawbone Big Jambox Micro USB Port Replacement: stap 5, afbeelding 2 van 2
      • Before unscrewing, take a picture of the top view. That way, when you're reassembling the device, you'll know the orientation of the metal grounding plates.
      • Unscrew the eight indicated T6 9.8 mm screws. Remove metal grounding plates.
      Vraag FixBot
      Voeg opmerking toe
    6. Jawbone Big Jambox Micro USB Port Replacement: stap 6, afbeelding 1 van 1
      • Once all eight screws are removed, pry the sides of the Jambox to lift the body from it's shell.
      Vraag FixBot
      Voeg opmerking toe
    7. Jawbone Big Jambox Micro USB Port Replacement: stap 7, afbeelding 1 van 1
      • With the battery facing forward, remove the three indicated T6 9.5 mm screws.
      • Once the screws are removed, lift up the small plastic plate, revealing the auxiliary board underneath.
      Vraag FixBot
      Voeg opmerking toe
    1. Jawbone Big Jambox Micro USB Port Replacement, Button Panel: stap 8, afbeelding 1 van 2 Jawbone Big Jambox Micro USB Port Replacement, Button Panel: stap 8, afbeelding 2 van 2
      • Turn the Jambox so that the button panel is visible.
      • Remove the indicated screws, T6 9.6 mm.
      • There is a small plastic flap obscuring the view of one of the screws, indicated in orange. In order to unscrew it, simply lift the flap out of the way.
      Vraag FixBot
      Voeg opmerking toe
    2. Jawbone Big Jambox Micro USB Port Replacement: stap 9, afbeelding 1 van 1
      • Pop off the button panel.
      Vraag FixBot
      Voeg opmerking toe
    3. Jawbone Big Jambox Micro USB Port Replacement: stap 10, afbeelding 1 van 2 Jawbone Big Jambox Micro USB Port Replacement: stap 10, afbeelding 2 van 2
      • Remove the colored ribbon that connects the green button circuit board to the blue auxiliary board by using your finger to lift the small black tabs that clamp down the ribbon.
      Vraag FixBot
      Voeg opmerking toe
    1. Jawbone Big Jambox Micro USB Port Replacement, Micro USB Port: stap 11, afbeelding 1 van 2 Jawbone Big Jambox Micro USB Port Replacement, Micro USB Port: stap 11, afbeelding 2 van 2
      • Remove the indicated T6 7.4 mm screw holding the auxiliary board in place.
      • Carefully lift the auxiliary board up and off to the side.
      Vraag FixBot
      Voeg opmerking toe
    2. Jawbone Big Jambox Micro USB Port Replacement: stap 12, afbeelding 1 van 2 Jawbone Big Jambox Micro USB Port Replacement: stap 12, afbeelding 2 van 2
      • With the auxiliary board removed, use a soldering iron to heat the metal attaching the Micro USB port (indicated on the image).
      • Remove the Micro USB port.
      • Exercise caution when handling the soldering iron due to extreme heat.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Gabriella Graham
1.181 Reputatie
3 handleidingen geschreven
Cal Poly, Team 24-5, Lancaster Spring 2015 Lid van Cal Poly, Team 24-5, Lancaster Spring 2015
CPSU-LANCASTER-S15S24G5
4 Leden
18 handleidingen geschreven
7Gids Commentaar
Hi, great guide. My jambox has a broken headphone input. Where can I buy one to solder in. Or can I buy an entire new aux board?
conrad lucero - Antwoord Deel
I'm also looking for a new headphone input. Where do I find one?
C Dare - Antwoord Deel
You guys keep failing to mention where to get replacement parts. Any ideas??
Dave Bornack - Antwoord Deel
Where do I purchase the replacement auxiliary port?
Patrick egan - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 43
Altijd: 10,222
