Ga door naar hoofdinhoud
Jam Voice Speaker Replacement
Wat je nodig hebt
    1. Jam Voice Speaker Replacement, Hard Mesh Cover: stap 1, afbeelding 1 van 2 Jam Voice Speaker Replacement, Hard Mesh Cover: stap 1, afbeelding 2 van 2
      • Insert the plastic opening tool underneath the mesh top.
      • Pry the cover open.
      • To reattach the cover, simply align the round posts on the bottom of the cover into the holes.
      Vraag FixBot
      Voeg opmerking toe
    1. Jam Voice Speaker Replacement, Motherboard: stap 2, afbeelding 1 van 1
      • Remove the four 7mm Phillips screws from the plastic cover.
      Vraag FixBot
      Voeg opmerking toe
    2. Jam Voice Speaker Replacement: stap 3, afbeelding 1 van 2 Jam Voice Speaker Replacement: stap 3, afbeelding 2 van 2
      • Remove the four 5mm Phillips screws that hold down the speaker in place.
      • Remove the two 6mm Phillips screws that hold down the plastic casing.
      Vraag FixBot
      Voeg opmerking toe
    3. Jam Voice Speaker Replacement: stap 4, afbeelding 1 van 1
      Gereedschap gebruikt in deze stap:
      Halberd Spudger
      $2.99
      • Once all six screws are removed, use a Halberd Spudger or similar tool to lift up the speaker.
      • Pull the speaker up and out.
      Vraag FixBot
      Voeg opmerking toe
    4. Jam Voice Speaker Replacement: stap 5, afbeelding 1 van 3 Jam Voice Speaker Replacement: stap 5, afbeelding 2 van 3 Jam Voice Speaker Replacement: stap 5, afbeelding 3 van 3
      • Remove the four 7mm Phillips screws to expose the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    5. Jam Voice Speaker Replacement: stap 6, afbeelding 1 van 1
      • After removing all of the screws from the plastic cover, remove it by pulling up and out.
      • Be careful not to pull and damage any of the wires.
      Vraag FixBot
      Voeg opmerking toe
    6. Jam Voice Speaker Replacement: stap 7, afbeelding 1 van 2 Jam Voice Speaker Replacement: stap 7, afbeelding 2 van 2
      • Remove the three 5mm Phillips screws that hold the motherboard in place.
      • After the screws are removed, place two fingers on the power button and Bluetooth button to push the motherboard out.
      Vraag FixBot
      Voeg opmerking toe
    1. Jam Voice Speaker Replacement, Speaker: stap 8, afbeelding 1 van 1
      • Use tweezers to pull out the speaker's wire from the motherboard.
      • Use tweezers to pull out the battery's wire from the motherboard.
      • The speaker's connection point is opposite the battery's connection point.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Alexander Buck
358 Reputatie
2 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 29
Altijd: 929
