Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Using a metal spudger, peel back the foam pad on the bottom of the device to reveal six screws.
Remove the six 20 mm T6 screws from the bottom of the device.
Remove the back plate and the grey foam underneath.
Use a small, pointed metal spudger to release the plastic tabs connecting the faceplate to the bottom of the speaker.
Slowly flip the device open like a clam shell.
Using the T6 Torx Screwdriver, remove the four (4mm) screws.
After removing the screws, take out the center covering to free the motherboard by lifting the tabs and pulling it off.
Peel off the white adhesive to desolder the connections underneath.
Desolder the wires connected to the motherboard.
4 andere personen hebben deze handleiding voltooid.
3 opmerkingen
Great walk-through... thanks
Be very careful when desoldering the connector cables! The soldering lugs are poor quality and tend to tear off the PCB
