Ga door naar hoofdinhoud
Jabra Speak 510 Motherboard Replacement
Wat je nodig hebt
  1. Jabra Speak 510 Motherboard Replacement, Outer Casing: stap 1, afbeelding 1 van 2 Jabra Speak 510 Motherboard Replacement, Outer Casing: stap 1, afbeelding 2 van 2
    • Using a metal spudger, peel back the foam pad on the bottom of the device to reveal six screws.
  2. Jabra Speak 510 Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Remove the six 20 mm T6 screws from the bottom of the device.
  3. Jabra Speak 510 Motherboard Replacement: stap 3, afbeelding 1 van 2 Jabra Speak 510 Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Remove the back plate and the grey foam underneath.
  4. Jabra Speak 510 Motherboard Replacement: stap 4, afbeelding 1 van 3 Jabra Speak 510 Motherboard Replacement: stap 4, afbeelding 2 van 3 Jabra Speak 510 Motherboard Replacement: stap 4, afbeelding 3 van 3
    • Use a small, pointed metal spudger to release the plastic tabs connecting the faceplate to the bottom of the speaker.
    • A small cable connects the faceplate to the device. Carefully disconnect the cable before fully opening the device.
    • Slowly flip the device open like a clam shell.
    • There are several wires soldered to the motherboard that prevent the faceplate from detaching completely.
  5. Jabra Speak 510 Motherboard Replacement, Motherboard: stap 5, afbeelding 1 van 2 Jabra Speak 510 Motherboard Replacement, Motherboard: stap 5, afbeelding 2 van 2
    • Using the T6 Torx Screwdriver, remove the four (4mm) screws.
  6. Jabra Speak 510 Motherboard Replacement: stap 6, afbeelding 1 van 1
    • After removing the screws, take out the center covering to free the motherboard by lifting the tabs and pulling it off.
  7. Jabra Speak 510 Motherboard Replacement: stap 7, afbeelding 1 van 2 Jabra Speak 510 Motherboard Replacement: stap 7, afbeelding 2 van 2
    • Peel off the white adhesive to desolder the connections underneath.
    • Desolder the wires connected to the motherboard.
    • You can find soldering tips in the How To Solder and Desolder Connections guide.
    • Keep track of where the wires are connected. When re-assembling you will have to connect the wires in the correct spot.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Jordan Murphy
717 Reputatie
3 handleidingen geschreven
IUPUI, Team 2-3, Harley Spring 2016 Lid van IUPUI, Team 2-3, Harley Spring 2016
IUPUI-HARLEY-S16S2G3
4 Leden
8 handleidingen geschreven
3 opmerkingen
Great walk-through... thanks
Walaa Maher - Antwoord
Be very careful when desoldering the connector cables! The soldering lugs are poor quality and tend to tear off the PCB
Thomas Sprenger - Antwoord
Hello
Where I can buy the motherboard replacement?
Regards
Lobo Gris - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 24
Afgelopen 30 dagen: 71
Altijd: 7,424
