Ga door naar hoofdinhoud
Jabra Freeway Motion Detector Replacement
Wat je nodig hebt
  1. Jabra Freeway Motion Detector Replacement, Front Panel: stap 1, afbeelding 1 van 3 Jabra Freeway Motion Detector Replacement, Front Panel: stap 1, afbeelding 2 van 3 Jabra Freeway Motion Detector Replacement, Front Panel: stap 1, afbeelding 3 van 3
    • Turn off the device before proceeding. Failure to do so may result in device damage or injury to oneself.
    • Remove the rubber pads from the bottom of the device using the spudger.
  2. Jabra Freeway Motion Detector Replacement: stap 2, afbeelding 1 van 3 Jabra Freeway Motion Detector Replacement: stap 2, afbeelding 2 van 3 Jabra Freeway Motion Detector Replacement: stap 2, afbeelding 3 van 3
    • Remove the eight 6mm T9 screws.
    • Two of these screws are underneath the foam padding. This padding is glued on and will be destroyed in this process. Poking through the foam minimizes the damage to the device.
  3. Jabra Freeway Motion Detector Replacement: stap 3, afbeelding 1 van 3 Jabra Freeway Motion Detector Replacement: stap 3, afbeelding 2 van 3 Jabra Freeway Motion Detector Replacement: stap 3, afbeelding 3 van 3
    • Gently lift the front panel off of the device and carefully rest it to the side.
  4. Jabra Freeway Motion Detector Replacement, Motion Detector: stap 4, afbeelding 1 van 3 Jabra Freeway Motion Detector Replacement, Motion Detector: stap 4, afbeelding 2 van 3 Jabra Freeway Motion Detector Replacement, Motion Detector: stap 4, afbeelding 3 van 3
    • Use the plastic opening tool to lift the motion detector off the circuit board.
    • The motion detector is glued in place, so a moderate amount of force is required.
  5. Jabra Freeway Motion Detector Replacement: stap 5, afbeelding 1 van 1
    • Desolder the two wires connecting the motion detector to the circuit board.
    • Please refer to the soldering technique guide for instructions on desoldering and soldering.
Conclusie
Alec Wilson
741 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 4-8, Catania Fall 2016 Lid van UMass Dartmouth, Team 4-8, Catania Fall 2016
UMASSD-CATANIA-F16S4G8
2 Leden
6 handleidingen geschreven
Één opmerking
Based on my limited experience with this device, the component being replaced here is the primary microphone - not the motion detector as claimed. The other video showing replacement of the microphone is actually the secondary, or noise-cancelling microphone. I don’t know the exact components for the motion detector, but I’m quite sure that this is not that component.
Steve MacLeod - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 11
Altijd: 502
