Inleiding
The bluetooth antenna in the Jabra Freeway is what allows the device to connect with your cellular device. This guide will help you to replace the antenna in the event of a failure.
Wat je nodig hebt
Carefully remove the rubber gasket using the tweezers.
Desolder the antenna wire from the circuit board.
Please refer to the soldering technique guide for instructions on desoldering and soldering.
Bijna klaar!
Conclusie
