Ga door naar hoofdinhoud
Jabra Evolve2 65 Battery Replacement
Wat je nodig hebt
  1. Jabra Evolve2 65 Battery Replacement, Ear Pads: stap 1, afbeelding 1 van 1
    • Lay your headphones down on a flat, solid surface.
    Vraag FixBot
    Voeg opmerking toe
  2. Jabra Evolve2 65 Battery Replacement: stap 2, afbeelding 1 van 2 Jabra Evolve2 65 Battery Replacement: stap 2, afbeelding 2 van 2
    • Insert an opening tool into the seam between the ear pad and driver housing, near the hinge.
    • Gently pry the ear pad away from the driver housing until it releases.
    Vraag FixBot
    Voeg opmerking toe
  3. Jabra Evolve2 65 Battery Replacement: stap 3, afbeelding 1 van 2 Jabra Evolve2 65 Battery Replacement: stap 3, afbeelding 2 van 2
    • Pry off the other ear pad in the same manner.
    Vraag FixBot
    Voeg opmerking toe
  4. Jabra Evolve2 65 Battery Replacement, Motherboard: stap 4, afbeelding 1 van 2 Jabra Evolve2 65 Battery Replacement, Motherboard: stap 4, afbeelding 2 van 2
    • Peel back the tape where the microphone's base connects to the headband.
    • Use a T6 Torx screwdriver to remove the single 2 mm screw.
    Vraag FixBot
    Voeg opmerking toe
  5. Jabra Evolve2 65 Battery Replacement: stap 5, afbeelding 1 van 1
    • Go about a third of the way around the first screw and peel back the tape to locate the second screw.
    • Use T6 Torx screwdriver to remove the single 2 mm screw.
    Vraag FixBot
    Voeg opmerking toe
  6. Jabra Evolve2 65 Battery Replacement: stap 6, afbeelding 1 van 1
    • Locate the third screw after peeling the tape off entirely after removing the second screw.
    • Use a T6 Torx screwdriver to remove the final 2 mm screw.
    Vraag FixBot
    Voeg opmerking toe
  7. Jabra Evolve2 65 Battery Replacement: stap 7, afbeelding 1 van 3 Jabra Evolve2 65 Battery Replacement: stap 7, afbeelding 2 van 3 Jabra Evolve2 65 Battery Replacement: stap 7, afbeelding 3 van 3
    • Use an opening tool to pry up and set aside the driver housing.
    • Gently remove the motherboard from the housing..
    Vraag FixBot
    Voeg opmerking toe
  8. Jabra Evolve2 65 Battery Replacement: stap 8, afbeelding 1 van 3 Jabra Evolve2 65 Battery Replacement: stap 8, afbeelding 2 van 3 Jabra Evolve2 65 Battery Replacement: stap 8, afbeelding 3 van 3
    • After locating the battery underneath, use a pair of tweezers to disconnect all connected cables.
    • Using tweezers, gently wiggle out the connector that joins the battery to the motherboard. The correct connector will be labeled on the motherboard and is the one that contains 2 wires, one black and one red.
    Vraag FixBot
    Voeg opmerking toe
  9. Jabra Evolve2 65 Battery Replacement: stap 9, afbeelding 1 van 1
    • Using a soldering iron, desolder the driver connections from the motherboard.
    • When reinstalling the driver to the motherboard, make sure you solder the driver connections to the correct terminals. The red wire goes to the "P" and the black wire goes to the "N."
    Vraag FixBot
    Voeg opmerking toe
  10. Jabra Evolve2 65 Battery Replacement, Battery: stap 10, afbeelding 1 van 3 Jabra Evolve2 65 Battery Replacement, Battery: stap 10, afbeelding 2 van 3 Jabra Evolve2 65 Battery Replacement, Battery: stap 10, afbeelding 3 van 3
    • Using an opening tool, gently pry out the battery.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
JPittsley
218 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team 3-2, Botvin Spring 2025 Lid van UMass Dartmouth, Team 3-2, Botvin Spring 2025
UMASSD-BOTVIN-S25S3G2
4 Leden
15 handleidingen geschreven
1Gids Commentaar
How do I get the battery replacement
KAMUGISHA ALLAN - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 60
Afgelopen 30 dagen: 303
Altijd: 2,452
