Ga door naar hoofdinhoud
JYX-S55 Battery Replacement
Wat je nodig hebt
  1. JYX-S55 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    • Remove the six screws around the perimeter of the top panel of the machine using a 2.5 mm flathead screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  2. JYX-S55 Battery Replacement: stap 2, afbeelding 1 van 1
    • Grip the top panel with your thumb at the bottom and fingers around the top. Lift the panel until it comes loose.
    Vraag FixBot
    Voeg opmerking toe
  3. JYX-S55 Battery Replacement: stap 3, afbeelding 1 van 2 JYX-S55 Battery Replacement: stap 3, afbeelding 2 van 2
    • Move the top panel backwards and away from you. Let the panel hang down behind the machine, as this will allow you to have access to the components within the machine.
    Vraag FixBot
    Voeg opmerking toe
  4. JYX-S55 Battery Replacement: stap 4, afbeelding 1 van 1
    • Use a nylon spudger to pry the battery free from the glue.
    • It is important to note do NOT use heat or sharp objects, as the lithium-ion battery is flammable and could potentially explode.
    Vraag FixBot
    Voeg opmerking toe
  5. JYX-S55 Battery Replacement: stap 5, afbeelding 1 van 1
    • Disconnect the red and black wires from the battery.
    • Remove the battery from the device.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Sarah Iceman
502 Reputatie
2 handleidingen geschreven
Marist, Team 1-5, Chaterdon Spring 2023 Lid van Marist, Team 1-5, Chaterdon Spring 2023
MARS-CHATERDON-S23S1G5
3 Leden
8 handleidingen geschreven
3Gids Commentaar
Hi, thanks for the pictures that really helped. What type of battery is needed? Can you email me at vrhaiza@gmail.com.
Rhaiza Villafranca - Antwoord Deel
Can you please advise what type of battery would be needed? What if I don't have a nylon spudger? What can I use in exchange?
Jasmine - Antwoord Deel
I opened the Karaoke machine:
Lithium-ion
Type- Lithium-ion Battery
Capacity: 3.7V/5200mAh
Model:18650C
Charging limited:4.2V
Date: 2022L1
M
DeniseCabral - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 30
Afgelopen 30 dagen: 170
Altijd: 8,249
