Ga door naar hoofdinhoud
JLab Pro-7 Battery Replacement
Wat je nodig hebt
  1. JLab Pro-7 Battery Replacement, JLab Pro-7 Disassembly: stap 1, afbeelding 1 van 1
    • The tools needed in order to complete this task are above in the tools section.
    • Grab your tablet and have your tools ready in order to open it and fix the components inside.
    Vraag FixBot
    Voeg opmerking toe
  2. JLab Pro-7 Battery Replacement: stap 2, afbeelding 1 van 1
    • At the bottom of the tablet there are two screws.
    • One screw is on the bottom left corner and the other is in the bottom right corner.
    • Here, you need to grab a small Phillips screwdriver and carefully take out these screws. Be careful not to strip the screws when taking them out.
    Vraag FixBot
    Voeg opmerking toe
  3. JLab Pro-7 Battery Replacement: stap 3, afbeelding 1 van 1
    • Now grab your iFixit prying tool and try to carefully pry off the back casing.
    • The back doesn't want to dislodge easily so make sure the end of your pry tool is underneath the screen in order to get enough leverage to start popping off the back case from the screen.
    • Be careful when prying the edge of your tablet! Avoid snapping the volume and lock buttons. Also try not to dig into the tablet too deep with your prying tool so you don't damage any components inside.
    Vraag FixBot
    Voeg opmerking toe
  4. JLab Pro-7 Battery Replacement: stap 4, afbeelding 1 van 1
    • Make sure to make your way around the perimeter of the tablet in order to take off the back casing.
    • Put small amounts of pressure around the perimeter until you see that section pop off.
    • Keep moving your way clockwise or counterclockwise until the back is fully removed.
    Vraag FixBot
    Voeg opmerking toe
  5. JLab Pro-7 Battery Replacement: stap 5, afbeelding 1 van 1
    • There you have it now the back should be fully removed.
    • Make sure to inspect your tablet for any damage from prying off the back panel of your panel.
    • If any internals did fall out or seem to be damaged check out our guides we may be able to help you!
    Vraag FixBot
    Voeg opmerking toe
  6. JLab Pro-7 Battery Replacement, Battery: stap 6, afbeelding 1 van 1
    • Once the prerequisite guide has been completed you will notice a large grey rectangle that takes up most of the back panel
    • This is the item that you will be replacing
    Vraag FixBot
    Voeg opmerking toe
  7. JLab Pro-7 Battery Replacement: stap 7, afbeelding 1 van 1
    • Taking off a battery should be handled with immense care. Take your time and make sure not to puncture the outer case of the battery. This can be both harmful to you and your device.
    • In the red circles are thermal tape that needs to be removed .
    • Gently remove each peace of thermal tape
    • The thermal tape itself isn't very sticky so there aren't any specialty tools needed
    Vraag FixBot
    Voeg opmerking toe
  8. JLab Pro-7 Battery Replacement: stap 8, afbeelding 1 van 2 JLab Pro-7 Battery Replacement: stap 8, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Once the thermal tape is removed, we need to remove the solder joints shown in the red circle and pointed to by our tweezers.
    • These are the only wires connecting the battery to the mother board.
    Vraag FixBot
    Voeg opmerking toe
  9. JLab Pro-7 Battery Replacement: stap 9, afbeelding 1 van 2 JLab Pro-7 Battery Replacement: stap 9, afbeelding 2 van 2
    • Soldering is a very useful, but dangerous technique to use. The iron itself gets very hot. In order to minimize and chance of bodily harm or damage of your product follow our links to soldering safety and instructions pages before proceeding
    • Soldering Instructions Soldering Safety
    • The first picture taken is from our speaker replacement guide.
    • Wait for your soldering iron to be hot and hold directly next to or barely touching the solder joints until they are liquid
    • Once the solder joint are liquid the wires are free to be taken off
    • The second picture is the solder joints that you want to heat with your soldering iron and then remove them in order o get 1 step closer to replacing your battery.
    Vraag FixBot
    Voeg opmerking toe
  10. JLab Pro-7 Battery Replacement: stap 10, afbeelding 1 van 1
    • In this step we will be using our iFixit prying tool in order to take out the battery.
    • At this point the thermal tape and solder joints should be removed via previous steps. This picture just yields a good vantage point of the battery itself.
    • The red arrows show where you will carefully pry the battery upward in order to remove the battery from the back panel.
    Vraag FixBot
    Voeg opmerking toe
  11. JLab Pro-7 Battery Replacement: stap 11, afbeelding 1 van 1
    • Use the iFixit plastic pry tool in order to pry the battery up from the metal plate it's stuck to.
    • Make sure to work your way around the battery marked by the red box. Slowly and gently prying up until it is completely detached from the back plate.
    Vraag FixBot
    Voeg opmerking toe
  12. JLab Pro-7 Battery Replacement: stap 12, afbeelding 1 van 1
    • Be careful of the wireless antenna when removing the battery using the pry tool
    • Make sure not to pry where the antenna is circled so you don't damage your device.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Richard Pooler
431 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team S2-G3, Isaacson Spring 2017 Lid van UMass Dartmouth, Team S2-G3, Isaacson Spring 2017
UMASSD-ISAACSON-S17S2G3
3 Leden
12 handleidingen geschreven
2Gids Commentaar
I have but one question. Maybe the most important one. Where do I find a replacement battery? Other wise this is a perfect guide I am ready to tackle.
Aaron Loyd - Antwoord Deel
I Found it and I fixed it.
2000mAh 3.7V lipo rechargeable Battery 306070 polymer lithium Li-Po USA
https://www.ebay.com/itm/224159433635
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 40
Altijd: 1,263
