Ga door naar hoofdinhoud
JBL Wave Beam Case Disassembly
Wat je nodig hebt
  1. JBL Wave Beam Case Disassembly, Heat up the case: stap 1, afbeelding 1 van 1
    • Open up your case and remove the earbuds. Prepare a heat gun at around 150℃, and gently heat up the front part of the case, around where the LED is.
    Vraag FixBot
    Voeg opmerking toe
  2. JBL Wave Beam Case Disassembly, Insert a plastic pick: stap 2, afbeelding 1 van 2 JBL Wave Beam Case Disassembly, Insert a plastic pick: stap 2, afbeelding 2 van 2
    • Now try to insert an opening pick into the seam as shown. If you can't get it in, try heating the case more or using a different pick.
    • Slide the pick around the edge of the case until it reaches the back, next to the hinge part. You can apply more heat here if this is too difficult.
    • Repeat with a second opening pick, going round the other side. The second image shows what your case should now look like.
    Vraag FixBot
    Voeg opmerking toe
  3. JBL Wave Beam Case Disassembly, Lift out the internals: stap 3, afbeelding 1 van 1
    • Use a plastic tool to lift up the internals as shown
    • If this is too difficult, you might want to use a third pick, and pry around the area under the LED.
    Vraag FixBot
    Voeg opmerking toe
  4. JBL Wave Beam Case Disassembly, Remove the electronics: stap 4, afbeelding 1 van 2 JBL Wave Beam Case Disassembly, Remove the electronics: stap 4, afbeelding 2 van 2
    • You should now have removed the outer case. Remove the two Phillips #0 screws next to the exposed USB port.
    • Pull the motherboard directly upwards. Be gentle here, as it is still connected to the glued-down battery
    • Use a plastic tool to pry out the battery, it is attached to the case with a sticky pad. If you have isopropyl alcohol, apply some underneath the battery to loosen the adhesive.
    Vraag FixBot
    Voeg opmerking toe
  5. JBL Wave Beam Case Disassembly, Desolder the battery: stap 5, afbeelding 1 van 1
    • The battery is connected to the motherboard with either 3 or 2 solder pads. Use a soldering iron and flux to remove all of them, being careful not to cause any shorts.
    Vraag FixBot
    Voeg opmerking toe
    • Solder the black and red wires of your new battery to GND and BATT on the motherboard, respectively. If there is a third wire (temperature sensor) solder it to the NTC pad.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Chris P. Croutonne
1.208 Reputatie
8 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 87
Afgelopen 30 dagen: 418
Altijd: 2,522
