Ga door naar hoofdinhoud
JBL Tune 510BT Volume Button Replacement
Wat je nodig hebt
  1. JBL Tune 510BT Volume Button Replacement, Faceplate: stap 1, afbeelding 1 van 2 JBL Tune 510BT Volume Button Replacement, Faceplate: stap 1, afbeelding 2 van 2
    • Firmly grasp the earmuff and pull away from the center until the lip of the earmuff is disengaged.
    • Pull the earmuff towards the center of the headphones until it is free.
  2. JBL Tune 510BT Volume Button Replacement: stap 2, afbeelding 1 van 2 JBL Tune 510BT Volume Button Replacement: stap 2, afbeelding 2 van 2
    • Remove the three 3 mm screws using a JIS #00 screwdriver.
  3. JBL Tune 510BT Volume Button Replacement: stap 3, afbeelding 1 van 1
    • Carefully remove the faceplate by lifting it firmly.
    • Avoid rough movements, as there is a single thin wire connecting the faceplate to the internals.
    • If the repair is for the right-side driver, be mindful of the charging port, as the faceplate has a slot there for it. Lift the opposite end and back the port out.
    • To completely detach the faceplate, desolder the wires from the connections on the motherboard.
  4. JBL Tune 510BT Volume Button Replacement, Volume Button: stap 4, afbeelding 1 van 2 JBL Tune 510BT Volume Button Replacement, Volume Button: stap 4, afbeelding 2 van 2
    • Remove the 1 mm screw using a JIS #00 screwdriver.
    • Using your finger or a Jimmy, gently pry the circuit board from the casing, being careful to not pull too hard to dislodge the connected wires.
  5. JBL Tune 510BT Volume Button Replacement: stap 5, afbeelding 1 van 3 JBL Tune 510BT Volume Button Replacement: stap 5, afbeelding 2 van 3 JBL Tune 510BT Volume Button Replacement: stap 5, afbeelding 3 van 3
    • Gently push the damaged volume button from the outside towards the inner part of the headphone casing until it dislodges.
    • Replace it with the new button by connecting the tabs at the top and swinging the button into place.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Ryan
609 Reputatie
4 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 48
Altijd: 1,315
