Ga door naar hoofdinhoud
JBL Pulse 3 LED Light Display Replacement
Wat je nodig hebt
    1. JBL Pulse 3 LED Light Display Replacement, Speaker Grill: stap 1, afbeelding 1 van 1
      • Lay the JBL Pulse 3 on its side as shown in the picture.
      • Use a plastic opening tool to lift the top right corner of the speaker grill. A small amount of force is necessary to remove the grill.
      Vraag FixBot
      Voeg opmerking toe
    2. JBL Pulse 3 LED Light Display Replacement: stap 2, afbeelding 1 van 1
      • Repeat step 1 for bottom right corner of speaker grill.
      Vraag FixBot
      Voeg opmerking toe
    3. JBL Pulse 3 LED Light Display Replacement: stap 3, afbeelding 1 van 2 JBL Pulse 3 LED Light Display Replacement: stap 3, afbeelding 2 van 2
      • After pulling the right side of the grill off, place thumb underneath grill as shown in the picture.
      • Lift and pull straight out to pull grill off the posts.
      Vraag FixBot
      Voeg opmerking toe
      • Repeat steps 1-3 for the left side of the speaker grill on the JBL Pulse 3. The speaker grill should now be completely removed from the JBL Pulse 3.
      Vraag FixBot
      Voeg opmerking toe
    1. JBL Pulse 3 LED Light Display Replacement, Outside Casing: stap 5, afbeelding 1 van 2 JBL Pulse 3 LED Light Display Replacement, Outside Casing: stap 5, afbeelding 2 van 2
      • Use a Phillips #00 screwdriver to remove the six black 6mm screws on the inside of the top of the bottom section.
      Vraag FixBot
      Voeg opmerking toe
    2. JBL Pulse 3 LED Light Display Replacement: stap 6, afbeelding 1 van 2 JBL Pulse 3 LED Light Display Replacement: stap 6, afbeelding 2 van 2
      • Turn the JBL Pulse 3 right-side up and unscrew the top ring of the device. A small amount of force and/or a cotton cloth may be necessary to remove this piece.
      Vraag FixBot
      Voeg opmerking toe
    3. JBL Pulse 3 LED Light Display Replacement: stap 7, afbeelding 1 van 2 JBL Pulse 3 LED Light Display Replacement: stap 7, afbeelding 2 van 2
      • Remove the six 5mm screws on top of the JBL Pulse 3 with a Phillips #0 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    4. JBL Pulse 3 LED Light Display Replacement: stap 8, afbeelding 1 van 1
      • Pull off the top disc of the JBL Pulse 3.
      Vraag FixBot
      Voeg opmerking toe
    5. JBL Pulse 3 LED Light Display Replacement: stap 9, afbeelding 1 van 2 JBL Pulse 3 LED Light Display Replacement: stap 9, afbeelding 2 van 2
      • Remove the five 7mm screws on the inside of the JBL Pulse 3 with a Phillips #1 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    6. JBL Pulse 3 LED Light Display Replacement: stap 10, afbeelding 1 van 2 JBL Pulse 3 LED Light Display Replacement: stap 10, afbeelding 2 van 2
      • Peel off black, taped-on electrical lead from the inside side of the JBL Pulse 3.
      Vraag FixBot
      Voeg opmerking toe
    7. JBL Pulse 3 LED Light Display Replacement: stap 11, afbeelding 1 van 1
      • Pull the top section of the JBL Pulse 3 up. The outside casing to the JBL Pulse 3 should now be removed.
      Vraag FixBot
      Voeg opmerking toe
    1. JBL Pulse 3 LED Light Display Replacement, LED Light Display: stap 12, afbeelding 1 van 3 JBL Pulse 3 LED Light Display Replacement, LED Light Display: stap 12, afbeelding 2 van 3 JBL Pulse 3 LED Light Display Replacement, LED Light Display: stap 12, afbeelding 3 van 3
      • Use a Phillips #2 screwdriver to remove the six 11 mm screws that circle the bottom of the LED light display.
      • Pull the LED light display off of the JBL Pulse 3 base.
      Vraag FixBot
      Voeg opmerking toe
    2. JBL Pulse 3 LED Light Display Replacement: stap 13, afbeelding 1 van 2 JBL Pulse 3 LED Light Display Replacement: stap 13, afbeelding 2 van 2
      Gereedschap gebruikt in deze stap:
      • Use tweezers to pull the five connections off of the LED light display.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
4Gids Commentaar
Hello,I really need some code to show me how to initialize and LED display and how to output data from it.Any help is much appreciated.
Osama Siddiq - Antwoord Deel
Wow jbl
Gyyzhuahyz8yus
Majd Tom - Antwoord Deel
Where to buy the leds?
mj.viana1993 - Antwoord Deel
Hello i need an assitance in a LED screen manufacturing
volkanoo - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 51
Altijd: 4,253
