Ga door naar hoofdinhoud
JBL Pulse 3 Charging Port Replacement
Wat je nodig hebt
    1. JBL Pulse 3 Charging Port Replacement, Speaker Grill: stap 1, afbeelding 1 van 1
      • Lay the JBL Pulse 3 on its side as shown in the picture.
      • Use a plastic opening tool to lift the top right corner of the speaker grill. A small amount of force is necessary to remove the grill.
      Vraag FixBot
      Voeg opmerking toe
    2. JBL Pulse 3 Charging Port Replacement: stap 2, afbeelding 1 van 1
      • Repeat step 1 for bottom right corner of speaker grill.
      Vraag FixBot
      Voeg opmerking toe
    3. JBL Pulse 3 Charging Port Replacement: stap 3, afbeelding 1 van 2 JBL Pulse 3 Charging Port Replacement: stap 3, afbeelding 2 van 2
      • After pulling the right side of the grill off, place thumb underneath grill as shown in the picture.
      • Lift and pull straight out to pull grill off the posts.
      Vraag FixBot
      Voeg opmerking toe
      • Repeat steps 1-3 for the left side of the speaker grill on the JBL Pulse 3. The speaker grill should now be completely removed from the JBL Pulse 3.
      Vraag FixBot
      Voeg opmerking toe
    1. JBL Pulse 3 Charging Port Replacement, Outside Casing: stap 5, afbeelding 1 van 2 JBL Pulse 3 Charging Port Replacement, Outside Casing: stap 5, afbeelding 2 van 2
      • Use a Phillips #00 screwdriver to remove the six black 6mm screws on the inside of the top of the bottom section.
      Vraag FixBot
      Voeg opmerking toe
    2. JBL Pulse 3 Charging Port Replacement: stap 6, afbeelding 1 van 2 JBL Pulse 3 Charging Port Replacement: stap 6, afbeelding 2 van 2
      • Turn the JBL Pulse 3 right-side up and unscrew the top ring of the device. A small amount of force and/or a cotton cloth may be necessary to remove this piece.
      Vraag FixBot
      Voeg opmerking toe
    3. JBL Pulse 3 Charging Port Replacement: stap 7, afbeelding 1 van 2 JBL Pulse 3 Charging Port Replacement: stap 7, afbeelding 2 van 2
      • Remove the six 5mm screws on top of the JBL Pulse 3 with a Phillips #0 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    4. JBL Pulse 3 Charging Port Replacement: stap 8, afbeelding 1 van 1
      • Pull off the top disc of the JBL Pulse 3.
      Vraag FixBot
      Voeg opmerking toe
    5. JBL Pulse 3 Charging Port Replacement: stap 9, afbeelding 1 van 2 JBL Pulse 3 Charging Port Replacement: stap 9, afbeelding 2 van 2
      • Remove the five 7mm screws on the inside of the JBL Pulse 3 with a Phillips #1 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    6. JBL Pulse 3 Charging Port Replacement: stap 10, afbeelding 1 van 2 JBL Pulse 3 Charging Port Replacement: stap 10, afbeelding 2 van 2
      • Peel off black, taped-on electrical lead from the inside side of the JBL Pulse 3.
      Vraag FixBot
      Voeg opmerking toe
    7. JBL Pulse 3 Charging Port Replacement: stap 11, afbeelding 1 van 1
      • Pull the top section of the JBL Pulse 3 up. The outside casing to the JBL Pulse 3 should now be removed.
      Vraag FixBot
      Voeg opmerking toe
    1. JBL Pulse 3 Charging Port Replacement, LED Light Display: stap 12, afbeelding 1 van 3 JBL Pulse 3 Charging Port Replacement, LED Light Display: stap 12, afbeelding 2 van 3 JBL Pulse 3 Charging Port Replacement, LED Light Display: stap 12, afbeelding 3 van 3
      • Use a Phillips #2 screwdriver to remove the six 11 mm screws that circle the bottom of the LED light display.
      • Pull the LED light display off of the JBL Pulse 3 base.
      Vraag FixBot
      Voeg opmerking toe
    2. JBL Pulse 3 Charging Port Replacement: stap 13, afbeelding 1 van 2 JBL Pulse 3 Charging Port Replacement: stap 13, afbeelding 2 van 2
      Gereedschap gebruikt in deze stap:
      • Use tweezers to pull the five connections off of the LED light display.
      Vraag FixBot
      Voeg opmerking toe
    1. JBL Pulse 3 Charging Port Replacement, Motherboard: stap 14, afbeelding 1 van 2 JBL Pulse 3 Charging Port Replacement, Motherboard: stap 14, afbeelding 2 van 2
      • Using a Phillips #0 screwdriver, remove the two black 8mm screws on the bottom of the LED light display.
      Vraag FixBot
      Voeg opmerking toe
    2. JBL Pulse 3 Charging Port Replacement: stap 15, afbeelding 1 van 3 JBL Pulse 3 Charging Port Replacement: stap 15, afbeelding 2 van 3 JBL Pulse 3 Charging Port Replacement: stap 15, afbeelding 3 van 3
      • Pull out the motherboard slightly from the LED light display as shown. Using tweezers, unplug the three connections attached to the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    3. JBL Pulse 3 Charging Port Replacement: stap 16, afbeelding 1 van 1
      • Pull the rest of the motherboard out from the LED light display.
      • Using wire cutters, snip the black wire connecting to the base of the JBL Pulse 3 at the base of the motherboard. The motherboard should now be removed from the JBL Pulse 3.
      Vraag FixBot
      Voeg opmerking toe
    1. JBL Pulse 3 Charging Port Replacement, Speaker: stap 17, afbeelding 1 van 2 JBL Pulse 3 Charging Port Replacement, Speaker: stap 17, afbeelding 2 van 2
      • Using a Phillips #2 screwdriver, remove the four 10mm screws on the corner of the speaker on the side of the base of the JBL Pulse 3.
      Vraag FixBot
      Voeg opmerking toe
    2. JBL Pulse 3 Charging Port Replacement: stap 18, afbeelding 1 van 2 JBL Pulse 3 Charging Port Replacement: stap 18, afbeelding 2 van 2
      • Pull out the speaker and cut the black and red wire with wire cutters. The speaker should now be removed from the JBL Pulse 3.
      Vraag FixBot
      Voeg opmerking toe
    1. JBL Pulse 3 Charging Port Replacement, Charging Port: stap 19, afbeelding 1 van 2 JBL Pulse 3 Charging Port Replacement, Charging Port: stap 19, afbeelding 2 van 2
      • Repeat the steps to take out all three speakers on the base of the JBL Pulse 3.
      • Using a Phillips #0 screwdriver, remove the 6 mm screw under each of the three speakers around the base of the JBL Pulse 3.
      Vraag FixBot
      Voeg opmerking toe
    2. JBL Pulse 3 Charging Port Replacement: stap 20, afbeelding 1 van 2 JBL Pulse 3 Charging Port Replacement: stap 20, afbeelding 2 van 2
      • Grab the outside of the JBL Pulse 3 at the bottom and pull outward until the outside button cover comes off.
      Vraag FixBot
      Voeg opmerking toe
    3. JBL Pulse 3 Charging Port Replacement: stap 21, afbeelding 1 van 2 JBL Pulse 3 Charging Port Replacement: stap 21, afbeelding 2 van 2
      • Disconnect the two connections from the inside side of the base of the JBL Pulse 3 by pushing on the wire with your index finger in the opposite direction of the connection.
      Vraag FixBot
      Voeg opmerking toe
    4. JBL Pulse 3 Charging Port Replacement: stap 22, afbeelding 1 van 2 JBL Pulse 3 Charging Port Replacement: stap 22, afbeelding 2 van 2
      • Using a Phillips #1 screwdriver, remove the four 10mm screws by the push buttons on the side of the base of the JBL Pulse 3.
      Vraag FixBot
      Voeg opmerking toe
    5. JBL Pulse 3 Charging Port Replacement: stap 23, afbeelding 1 van 1
      • Pull off the inside button cover with the attached charging port. The charging port should now be removed.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
6 andere personen hebben deze handleiding voltooid.
5Gids Commentaar
And how to put it back with cut cable?
Robert Rpunkt - Antwoord Deel
Good very good
Shadow Takeshi - Antwoord Deel
I've done a teardown and was able to access the charging terminal without cutting any wires. I didn't have a replacement, so I just put it back together hoping that cleaning it would work. Didn't work.
Beresford Crowder - Antwoord Deel
Yeah its obvious they need to use a C type port they aren't as easy to tear up
Lloyd Mars - Antwoord Deel
You do not have to tear it completely down unless I have a newer version after you take the speaker grill out from around the unit the thin black skeleton like gram that stiffened the grill will actually unclip from the unit with a hook tool or a ice pick that's been heated up and put a slight bend in it take your time because you can break the frame but even if you do its what they make jb weld and gorilla glue for I broke mine but went back together fine after letting the glue set up sprinkled some baking soda on it and made it twice as strong you've only got 4 screws this way cause they well the replacement plug for around $12 don't know why they don't go ahead and use the C type port smh when these came out they was already selling the replacement plug lol
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 48
Afgelopen 30 dagen: 125
Altijd: 19,651
