Ga door naar hoofdinhoud
JBL Go Repair Motherboard Replacement
Wat je nodig hebt
  1. JBL Go Repair Motherboard Replacement, Front Cover: stap 1, afbeelding 1 van 1
    • Use an opening tool to scrape around the outside of the front cover to remove the glue attaching it to the surrounding rubber layer.
    Vraag FixBot
    Voeg opmerking toe
  2. JBL Go Repair Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Once you have scraped off all of the glue, use the opening tool to pry up the front cover.
    Vraag FixBot
    Voeg opmerking toe
  3. JBL Go Repair Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Carefully remove the loose plastic cover from the speaker.
    Vraag FixBot
    Voeg opmerking toe
  4. JBL Go Repair Motherboard Replacement, Motherboard: stap 4, afbeelding 1 van 1
    • Once the front cover is removed, use a T6 screwdriver to remove the four 9 mm screws on the black cover.
    Vraag FixBot
    Voeg opmerking toe
  5. JBL Go Repair Motherboard Replacement: stap 5, afbeelding 1 van 1
    • After removing the screws, use the plastic opening tool to carefully pry around the edges of the black cover to loosen and lift the cover off of the device.
    Vraag FixBot
    Voeg opmerking toe
  6. JBL Go Repair Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Carefully unplug the woofer wires from the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  7. JBL Go Repair Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Use the T6 screwdriver to remove the 9 mm screw that secures the motherboard in place.
    Vraag FixBot
    Voeg opmerking toe
  8. JBL Go Repair Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Lift the motherboard using the plastic opening tool and stick it through the hole in the middle of the board.
    Vraag FixBot
    Voeg opmerking toe
  9. JBL Go Repair Motherboard Replacement: stap 9, afbeelding 1 van 1
    • Carefully lift the motherboard, sliding the charging port side out of the frame of the speaker as you go.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
9 andere personen hebben deze handleiding voltooid.
Sydney Jason
854 Reputatie
4 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 27
Afgelopen 30 dagen: 147
Altijd: 6,455
