Ga door naar hoofdinhoud
JBL Flip Bluetooth U.FL Antenna Connector Replacement
Wat je nodig hebt
  1. JBL Flip Bluetooth U.FL Antenna Connector Replacement, JBL Flip disassembly: stap 1, afbeelding 1 van 3 JBL Flip Bluetooth U.FL Antenna Connector Replacement, JBL Flip disassembly: stap 1, afbeelding 2 van 3 JBL Flip Bluetooth U.FL Antenna Connector Replacement, JBL Flip disassembly: stap 1, afbeelding 3 van 3
    • On the end with the buttons, remove the end cap using the flat head screwdriver to get between the rubber lining and the plastic.
    • After the cap is removed, unscrew the two 3.3mm screws using a size 1 ph screw driver.
  2. JBL Flip Bluetooth U.FL Antenna Connector Replacement: stap 2, afbeelding 1 van 3 JBL Flip Bluetooth U.FL Antenna Connector Replacement: stap 2, afbeelding 2 van 3 JBL Flip Bluetooth U.FL Antenna Connector Replacement: stap 2, afbeelding 3 van 3
    • Unscrew four 3.3mm screws on each end of the JBL using a size 1 ph screw driver (8 screws total).
  3. JBL Flip Bluetooth U.FL Antenna Connector Replacement: stap 3, afbeelding 1 van 3 JBL Flip Bluetooth U.FL Antenna Connector Replacement: stap 3, afbeelding 2 van 3 JBL Flip Bluetooth U.FL Antenna Connector Replacement: stap 3, afbeelding 3 van 3
    • Remove outermost white casing by gently lifting up on one side.
    • Remove two 5mm screws holding the silver back plate in place with a size 2 ph screw driver.
    • Gently lift up and remove the silver casing.
  4. JBL Flip Bluetooth U.FL Antenna Connector Replacement: stap 4, afbeelding 1 van 1
    • Remove last white back plate to expose the back of the speaker cover.
  5. JBL Flip Bluetooth U.FL Antenna Connector Replacement: stap 5, afbeelding 1 van 3 JBL Flip Bluetooth U.FL Antenna Connector Replacement: stap 5, afbeelding 2 van 3 JBL Flip Bluetooth U.FL Antenna Connector Replacement: stap 5, afbeelding 3 van 3
    • Pry the four tabs on each side of the speaker cover (8 tabs total).
    • Pry the two tabs on each end to remove the cover (4 tabs total).
    • Slide speaker out of metal speaker cover.
  6. JBL Flip Bluetooth U.FL Antenna Connector Replacement: stap 6, afbeelding 1 van 3 JBL Flip Bluetooth U.FL Antenna Connector Replacement: stap 6, afbeelding 2 van 3 JBL Flip Bluetooth U.FL Antenna Connector Replacement: stap 6, afbeelding 3 van 3
    • Remove 5mm screw in the middle of the back of the device with a size 2 ph screw driver.
    • Unscrew the two 5mm screws on each side using a size 2 ph screwdriver.
    • Open the speaker.
  7. JBL Flip Bluetooth U.FL Antenna Connector Replacement, Bluetooth Antenna U.FL Connector: stap 7, afbeelding 1 van 1
    • Use the prerequisite guide for removing the speaker housing.
  8. JBL Flip Bluetooth U.FL Antenna Connector Replacement: stap 8, afbeelding 1 van 2 JBL Flip Bluetooth U.FL Antenna Connector Replacement: stap 8, afbeelding 2 van 2
    • Disconnect all cables that are attached to the motherboard so that it resembles the step picture.
    • Make sure that the battery is turned off before removing cables.
  9. JBL Flip Bluetooth U.FL Antenna Connector Replacement: stap 9, afbeelding 1 van 1
    • Locate the underside of the motherboard, where the square U.FL antenna connector is.
  10. JBL Flip Bluetooth U.FL Antenna Connector Replacement: stap 10, afbeelding 1 van 1
    • Use the soldering iron to desolder the U.FL antenna connector. You might need to use a desoldering braid wire to remove the excess of solder.
    • Soldering iron will be very hot.
    • Clean the PCB pads of any excess of solder with the soldering braid wire before continuing.
    • Place the new U.FL connector on the pads where the desoldered connector was. Make sure the orientation of the connector is the same as before.
    • Solder the new U.FL connector to the PCB. Avoid exessive heat and/or prolongated soldering time during this step.
Conclusie
Be careful when connecting again the mini coaxial cable to the just replaced U.FL antenna connector, so it does not get damaged again.
Één andere persoon heeft deze handleiding voltooid.
Dillon
1.556 Reputatie
5 handleidingen geschreven
Colorado Springs, Team 9-5, Panko Spring 2015 Lid van Colorado Springs, Team 9-5, Panko Spring 2015
UCCS-PANKO-S15S9G5
3 Leden
2 opmerkingen
Where can i buy this awm flat cable that is connected to a stering buttons
Kuba - Antwoord
Hi, nice instructions. However, the description and text on the guide are misleading. The damaged part is the U.FL connector for the Bluetooth antenna, but not the antenna itself. I have edited some text on the guide for a better description of what is being repaired.
Emilio Martinez - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 49
Altijd: 10,676
