Ga door naar hoofdinhoud
JBL Flip 3 USB Port Replacement
Wat je nodig hebt
  1. JBL Flip 3 USB Port Replacement, Remove the speaker grill: stap 1, afbeelding 1 van 3 JBL Flip 3 USB Port Replacement, Remove the speaker grill: stap 1, afbeelding 2 van 3 JBL Flip 3 USB Port Replacement, Remove the speaker grill: stap 1, afbeelding 3 van 3
    • Remove the speaker grill using hands or a standard spudger.
    • Re-assembly Notes
    • Note the three alignment pins on the inner part of the housing and take care to line these up and insert the pins into the receivers on the chassis fully
    • With the pins fully engaged in the middle, pull the long edges away from the chassis slightly and then squeeze to engage the plastic clips into the chassis (two per edge, at the top and bottom.
  2. JBL Flip 3 USB Port Replacement, Remove Outer Frame Screws: stap 2, afbeelding 1 van 2 JBL Flip 3 USB Port Replacement, Remove Outer Frame Screws: stap 2, afbeelding 2 van 2
    • Remove the ten screws of the outer frame.
    • Six (6) screws along the thin long edge that are screwed in the chassis
    • Four (4) screws ( 2 per end) holding the ends to the chassis.
    • Reassembly Notes
    • Do not over-tighten screws.
  3. JBL Flip 3 USB Port Replacement, Remove the outer frame: stap 3, afbeelding 1 van 3 JBL Flip 3 USB Port Replacement, Remove the outer frame: stap 3, afbeelding 2 van 3 JBL Flip 3 USB Port Replacement, Remove the outer frame: stap 3, afbeelding 3 van 3
    • Pull on one end gently and remove the outer frame.
    • Remove the silicone button cover
    • Re-assembly Notes
    • Insert the silicone button cover first.
    • Line-up the bottom end first and carefully guide the USB port cover through the matching hole as you insert the top end.
  4. JBL Flip 3 USB Port Replacement, Remove the speaker end caps: stap 4, afbeelding 1 van 2 JBL Flip 3 USB Port Replacement, Remove the speaker end caps: stap 4, afbeelding 2 van 2
    • Remove the twelve screws that hold the two speaker end caps (6 per end)
    • Re-assembly notes
    • Align the two holes that are closest together (and pin underneath) to match the chassis holes first to align the entire end cap.
    • Tighten the six (6) screws per end cap (12 total). Do not over-tighten.
  5. JBL Flip 3 USB Port Replacement, Disconnect Ribbon Cable: stap 5, afbeelding 1 van 3 JBL Flip 3 USB Port Replacement, Disconnect Ribbon Cable: stap 5, afbeelding 2 van 3 JBL Flip 3 USB Port Replacement, Disconnect Ribbon Cable: stap 5, afbeelding 3 van 3
    • Carefully lift the retaining tab and pull ribbon cable out of the connector.
    • Note: Black plastic tab can fall out easily, so note orientation in the picture before re-inserting tab if it fell out.
    • For re-assembly, guide ribbon cable through the hole before re-inserting and closing the tab.
  6. JBL Flip 3 USB Port Replacement, Remove Control Panel: stap 6, afbeelding 1 van 2 JBL Flip 3 USB Port Replacement, Remove Control Panel: stap 6, afbeelding 2 van 2
    • Remove the six (6) screws retaining the control panel to access the USB Port (battery is also visible).
    • For re-assembly: do not overtighten screws.
  7. JBL Flip 3 USB Port Replacement, Remove the silicone holding the wires in the end cap cavity: stap 7, afbeelding 1 van 2 JBL Flip 3 USB Port Replacement, Remove the silicone holding the wires in the end cap cavity: stap 7, afbeelding 2 van 2
    • From the end cap side, remove the silicone holding the wires in place.
    • Proceed carefully Make sure the speaker is powered off. Avoid cutting the wires. A plastic ustensil is probably best, or a very small, dull screwdriver.
    • This took me about 30 minutes and I forgot to take pictures.
    • Disconnect the AUX input plug and then pull that wire out from under the PCB so it can be aligned with the hole.
    • Re-assembly Notes.
    • Push the AUX wiring between the PCB and the chassis.
    • Plug the AUX connector back in.
  8. JBL Flip 3 USB Port Replacement, Pull out the USB Port PCB: stap 8, afbeelding 1 van 3 JBL Flip 3 USB Port Replacement, Pull out the USB Port PCB: stap 8, afbeelding 2 van 3 JBL Flip 3 USB Port Replacement, Pull out the USB Port PCB: stap 8, afbeelding 3 van 3
    • Pull up on the USB Port PCB to break the lower glue/seal
    • Pull PCB out and rotate upward to align wiring
    • Gently guide wires at the end cap through the hole to extend the USB Port PCB as far out as possible.
    • Re-assembly Notes Pull the wiring from the end cap while aligning and inserting the PCB back in.
  9. JBL Flip 3 USB Port Replacement, Unsolder connectors: stap 9, afbeelding 1 van 3 JBL Flip 3 USB Port Replacement, Unsolder connectors: stap 9, afbeelding 2 van 3 JBL Flip 3 USB Port Replacement, Unsolder connectors: stap 9, afbeelding 3 van 3
    • WARNING! The two white connectors are not plugs. Do not attempt to pull them out.
    • IMPORTANT Take note or a picture of the wiring color and orientation for re-assembly later.
    • Unsolder the two connectors from the PCB.
  10. JBL Flip 3 USB Port Replacement, Replace the USB Port: stap 10, afbeelding 1 van 3 JBL Flip 3 USB Port Replacement, Replace the USB Port: stap 10, afbeelding 2 van 3 JBL Flip 3 USB Port Replacement, Replace the USB Port: stap 10, afbeelding 3 van 3
    • Unsolder the old USB Port.
    • WARNING! There are two different JBL Flip 3 speaker USB Ports. Order a replacement port of the same type that you have in your speaker.
    • Solder the new USB Port (5 pins and 4 mounting tabs)
    • Perform a continuity check to make sure none of the pins are bridged.
  11. JBL Flip 3 USB Port Replacement, Resolder the two connectors: stap 11, afbeelding 1 van 3 JBL Flip 3 USB Port Replacement, Resolder the two connectors: stap 11, afbeelding 2 van 3 JBL Flip 3 USB Port Replacement, Resolder the two connectors: stap 11, afbeelding 3 van 3
    • Align the connector holes in the correct orientation for each plug, and solder to the USB Port PCB.
  12. JBL Flip 3 USB Port Replacement, Test the new USB & AUX ports: stap 12, afbeelding 1 van 2 JBL Flip 3 USB Port Replacement, Test the new USB & AUX ports: stap 12, afbeelding 2 van 2
    • Gently return the USB Port PCB to it's location while gently pulling on the wires at the end.
    • Reconnect temporarily the AUX connector
    • Reconnect temporarily the Ribbon Cable to the control panel
    • Power on the speaker, and then insert a USB charger to ensure that the battery charges properly.
    • Test the AUX input to ensure it is still working.
    • Following a successful test, disconnect the control panel ribbon cable and the AUX plug.
    • Re-assemble the speaker in reverse order, taking note of the re-assembly notes provided at each step.
Conclusie
50 andere personen hebben deze handleiding voltooid.
College Student
3.512 Reputatie
4 handleidingen geschreven
USF Tampa, Team S1-G2, Leahy Spring 2017 Lid van USF Tampa, Team S1-G2, Leahy Spring 2017
USFT-LEAHY-S17S1G2
5 Leden
18 handleidingen geschreven
24 opmerkingen
how can i find the part..email me at leedeen2000@yahoo.com plz
leedeen2000 - Antwoord
I feel that the difficulty is just because of the lack of detail on the instructions. I also need to find the part, but where do I get it? I searched on eBay, Amazon and got nothing. That means that I have to scavenge this part from another one?
rodri.mendoza.t - Antwoord
i already got step 5, but i need know how i can get the replacement ? Any idea ?
PabloM - Antwoord
Looking for the part 2…
Daniel Brockbank - Antwoord
Looking for the same thing…
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 21
Afgelopen 7 dagen: 110
Afgelopen 30 dagen: 307
Altijd: 63,518
