Inleiding
The speaker is the main part of the JBL Clip+. This guide will show how to remove this.
Wat je nodig hebt
Use the angled tweezers to carefully pull the rubber bumper off the back side of the device
There are three solder points that need to be desoldered.
If you need help with desoldering refer to How to Solder and Desolder Connections help. After these are removed the battery should be free.
There are two #1 philips head 4mm screw fastening the speaker to the body, remove these.
Remove the solder on the motherboard.
If you are unsure how to desolder these connections refer to : How To Solder and Desolder Connections
4 andere personen hebben deze handleiding voltooid.
2 opmerkingen
do you know were can i buy the new speaker for my jbl clip +?
I work in A/V. I frequently need to adjust audio systems.
I want to add a switch to the speaker wire, so I can turn the speaker off, and use the line out port only, in order to test audio systems with a Bluetooth reciver.
I can be at the mixing board, adjusting sliders while the music is playing, with no cables.
Will this work?
