Ga door naar hoofdinhoud
JBL Clip Plus Battery Replacement
Wat je nodig hebt
  1. JBL Clip Plus Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Use the angled tweezers to carefully pull the rubber bumper off the back side of the device
  2. JBL Clip Plus Battery Replacement: stap 2, afbeelding 1 van 1
    • There will be three 6mm philips head screws under that rubber bumper, remove these three screws.
  3. JBL Clip Plus Battery Replacement: stap 3, afbeelding 1 van 1
    • The back cover should lift open easily and the components should be visible.
  4. JBL Clip Plus Battery Replacement: stap 4, afbeelding 1 van 1
    • The battery is adhered to the back cover of the JBL Clip Plus, slowly lift the battery away from the case, using a spudger to pry the battery away from the adhesive.
  5. JBL Clip Plus Battery Replacement: stap 5, afbeelding 1 van 1
    • Remove the three 7mm philips head screws on the outer edges of the device.
  6. JBL Clip Plus Battery Replacement: stap 6, afbeelding 1 van 1
    • Use the plastic prying tool to gently remove the face of the speaker from the body.
  7. JBL Clip Plus Battery Replacement: stap 7, afbeelding 1 van 1
    • Use the spudger tool to gently scrape away the adhesive holding in the microphone.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
  8. JBL Clip Plus Battery Replacement: stap 8, afbeelding 1 van 1
    • Gently push the motherboard away from the microphone, this will allow you to remove the microphone.
  9. JBL Clip Plus Battery Replacement: stap 9, afbeelding 1 van 1
    • Gently push the motherboard out from the frame of the JBL Clip Plus, this requires some force.
  10. JBL Clip Plus Battery Replacement: stap 10, afbeelding 1 van 1
    • There are three solder points that need to be desoldered.
    • If you need help with desoldering refer to How to Solder and Desolder Connections help. After these are removed the battery should be free.
Conclusie
15 andere personen hebben deze handleiding voltooid.
Noah Pauk
809 Reputatie
3 handleidingen geschreven
IUPUI, Team 3-4, Baechle Spring 2016 Lid van IUPUI, Team 3-4, Baechle Spring 2016
IUPUI-BAECHLE-S16S3G4
4 Leden
6 handleidingen geschreven
16 opmerkingen
Is it possible if replaced with a battery from cellphones with higher AmH rating?
Patrick Ignacio - Antwoord
Unfortunately, it would be hard to find a cell battery this small. The original battery is 2" x 1 1/8" x 1/8". My samsung S3 battery is 2 1/2" x 2" x 3/16", so is far from fitting. If you were ok with shaving the molded battery holder down, you could probably fit one that's 2" x 1 1/2" x 1/4" or so (the thickness tolerance is hard to tell), but it would be a lot of work. I think I might just buy a speaker that has good battery reputation (i.e., NOT JBL).
Kael Shipman -
man need to replace the speaker were can i buy just that?
ruitherock - Antwoord
I think Id rather just buy a different speaker.
Lynne Norris - Antwoord
"No parts required."
Seriously? How about a new battery!
Also, mentioning the battery model or a link to a replacement battery would have been very useful.
Dan M - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 29
Afgelopen 30 dagen: 164
Altijd: 24,435
