Ga door naar hoofdinhoud
JBL Clip 2 Battery Replacement
Wat je nodig hebt
  1. JBL Clip 2 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Begin by removing the front cap of the JBL Clip 2 by using the blue plastic opening tool to get in between the creases.
    • If your JBL Clip 2 has never been opened this procedure will require moderate amount of force.
  2. JBL Clip 2 Battery Replacement: stap 2, afbeelding 1 van 1
    • There will be six 3 mm T8 screws under the cap, remove these six screws.
    • If you are not trying to replace the speaker please ignore the two middle 3 mm T8 screws during this procedure.
  3. JBL Clip 2 Battery Replacement: stap 3, afbeelding 1 van 1
    • The front cover will lift open easily and the components will be visible.
  4. JBL Clip 2 Battery Replacement: stap 4, afbeelding 1 van 1
    • To completely remove the top portion, disconnect the speaker from the motherboard using the blue plastic opening tool.
    • While disconnecting be sure to not use too much force as these two parts are meant to become disconnected.
  5. JBL Clip 2 Battery Replacement: stap 5, afbeelding 1 van 1
    • There will be four 3 mm T8 screws holding the motherboard in place, remove these four screws.
  6. JBL Clip 2 Battery Replacement: stap 6, afbeelding 1 van 1
    • Slightly move the motherboard to the side to reveal sides of battery, carefully using the blue plastic opening tool to remove the battery from the speaker casing.
    • Be careful not to disconnect any soldered wires connected to the motherboard and speaker casing.
  7. JBL Clip 2 Battery Replacement: stap 7, afbeelding 1 van 1
    • Carefully looking at the motherboard there are three solder points labeled battery, that need to be desoldered.
    • If you need help with desoldering refer to How to Solder and Desolder Connections help. After these are removed the battery should be free.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Michael Hong
1.014 Reputatie
5 handleidingen geschreven
UW Tacoma, Team 2-2, Rose Winter 2017 Lid van UW Tacoma, Team 2-2, Rose Winter 2017
UWT-ROSE-W17S2G2
4 Leden
7 handleidingen geschreven
5 opmerkingen
How can this be a battery replacement if "no parts required", like it says?
Also, this fixit is really only half done without information as to the model of the battery needed for a replacement, or at least some specs like size, volts, mAh, etc. You've already done the hard work it would seem, so why not share it. Otherwise everyone doing this is forced to take it apart before trying to then figure out the battery they need to replace... then more waiting to order and ship and etc. etc.
Dan M - Antwoord
This is foolish as you needed the internet to post. Type in “JBL clip 2 battery replacement” (copy the quotation if your laziness knows no bounds) to the search bar, no “specs necessary” and when it arrives you will have no problem following his perfect directions. Don't try to be an articulate troll.
piercemathwig2006 - Antwoord
My replacement battery only has 2 wires the clip has 3 ?
insphats - Antwoord
Are you sure your watching the right instructions for the model you own? If 2 wires, and the right battery was bought, then it also should have 2 wires. IF 3 wires on the battery, perhaps the wrong model battery was ordered for your device. Watching a teardown video just now, this “ JBL Clip 2” has 3 wires. It is always a possibility that JBL used a version 1 and version 2 battery / motherboard in the JBL Clip 2’s.. you would be the one to determine that.
Just Me -
Motherboard anchored into shell with thick black adhesive/epoxy that would destroy components when accessing battery for replacement. Guide TOTALLY fails to note this. This FixIt is incomplete/inaccurate.
MadMapMan - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 18
Afgelopen 30 dagen: 79
Altijd: 12,828
