Ga door naar hoofdinhoud
JBL Charge 5 Charging Port Assembly Replacement
Wat je nodig hebt
  1. JBL Charge 5 Charging Port Assembly Replacement, Fabric Case: stap 1, afbeelding 1 van 3 JBL Charge 5 Charging Port Assembly Replacement, Fabric Case: stap 1, afbeelding 2 van 3 JBL Charge 5 Charging Port Assembly Replacement, Fabric Case: stap 1, afbeelding 3 van 3
    • Ensure that the device is fully powered off and no cables are attached before proceeding with the repair.
    • This fabric cover is secured with plastic clips only. Depending on the model, the cover may be secured by both plastic clips and screws.
    • Insert the flat end of the Jimmy into the seam located between the fabric cover on the right side of the seam.
    • Pry upward on the fabric cover to release plastic clips on the right side of the seam.
  2. JBL Charge 5 Charging Port Assembly Replacement: stap 2, afbeelding 1 van 3 JBL Charge 5 Charging Port Assembly Replacement: stap 2, afbeelding 2 van 3 JBL Charge 5 Charging Port Assembly Replacement: stap 2, afbeelding 3 van 3
    • Insert the flat end of the Jimmy into the seam between the fabric cover at the center of the seam and the left side of the seam.
    • Use the Jimmy to pry open the edge with the rubber texture, releasing the remaining plastic clips.
  3. JBL Charge 5 Charging Port Assembly Replacement: stap 3, afbeelding 1 van 3 JBL Charge 5 Charging Port Assembly Replacement: stap 3, afbeelding 2 van 3 JBL Charge 5 Charging Port Assembly Replacement: stap 3, afbeelding 3 van 3
    • Use your hands to gently open the two halves of the casing and slide the fabric cover off of the interior housing.
  4. JBL Charge 5 Charging Port Assembly Replacement, Charging Port Assembly: stap 4, afbeelding 1 van 3 JBL Charge 5 Charging Port Assembly Replacement, Charging Port Assembly: stap 4, afbeelding 2 van 3 JBL Charge 5 Charging Port Assembly Replacement, Charging Port Assembly: stap 4, afbeelding 3 van 3
    • Use a Phillips #0 screwdriver to remove the four 10.6 mm screws on the charging port cover.
  5. JBL Charge 5 Charging Port Assembly Replacement: stap 5, afbeelding 1 van 3 JBL Charge 5 Charging Port Assembly Replacement: stap 5, afbeelding 2 van 3 JBL Charge 5 Charging Port Assembly Replacement: stap 5, afbeelding 3 van 3
    • Use the opening tool or spudger to undo the clips.
    • Do not immediately remove the charging port.
  6. JBL Charge 5 Charging Port Assembly Replacement: stap 6, afbeelding 1 van 3 JBL Charge 5 Charging Port Assembly Replacement: stap 6, afbeelding 2 van 3 JBL Charge 5 Charging Port Assembly Replacement: stap 6, afbeelding 3 van 3
    • Rotate the device to the left, and push the left passive bass radiator off of the frame of the device using the metal spudger.
  7. JBL Charge 5 Charging Port Assembly Replacement: stap 7, afbeelding 1 van 3 JBL Charge 5 Charging Port Assembly Replacement: stap 7, afbeelding 2 van 3 JBL Charge 5 Charging Port Assembly Replacement: stap 7, afbeelding 3 van 3
    • Pinch the charging port connector and gently remove the blue and black no-fuss ribbon cable from the board.
    • Pinch the connector with both fingers when removing it to ensure the ribbon cable will not tear.
  8. JBL Charge 5 Charging Port Assembly Replacement: stap 8, afbeelding 1 van 3 JBL Charge 5 Charging Port Assembly Replacement: stap 8, afbeelding 2 van 3 JBL Charge 5 Charging Port Assembly Replacement: stap 8, afbeelding 3 van 3
    • Using both fingers, remove the charging port assembly.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Kat Whaley
753 Reputatie
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 25
Afgelopen 30 dagen: 116
Altijd: 564
