Ga door naar hoofdinhoud
JBL Charge 3 luidspreker vervangen
Wat je nodig hebt
  1. JBL Charge 3 luidspreker vervangen, Voorkant: stap 1, afbeelding 1 van 3 JBL Charge 3 luidspreker vervangen, Voorkant: stap 1, afbeelding 2 van 3 JBL Charge 3 luidspreker vervangen, Voorkant: stap 1, afbeelding 3 van 3
    • Draai je luidspreker ondersteboven en steek het plastic openingsgereedschap verticaal in de gleuf in de voorklep.
    • Trek het plastic openingsgereedschap langzaam naar buiten om de vier clips te verwijderen die de bekleding op zijn plaats houden.
    • Herhaal dit proces voor alle vier de randen van de voorkant
    Sometimes disassemblers forget that the first time they disassembled the item it didn’t want to give up easily: I didn’t like the forces I was having to apply at all, so I switched to two plastic prying tools per “corner” and one in-between them (total 5, you could use plectrums…) before I was happy the the forces were low enough not to break anything.
    Frank Puranik - Antwoord
    the front grill is supposed to be first not the back the back has longer while the front has shorter clip
    Water Bass Tester (Water BT) - Antwoord
    There are two Phillips head screws to remove before prying the cover off
    jason - Antwoord
    Where in south Africa can I buy jbl charge3 port bay replacement
    Donovan Fransman - Antwoord
    There appears to be different versions of the Charge 3. If you find it difficult to pry open a second side the two small screws mentioned by Jason will need to be removed but it also indicates that there will be some additional changes to this tear down that I will try to convey in the comments as well.
    john Ramirez - Antwoord
    Sadly I damaged the latches on my charge 3. There was more to it than just prying the front cover up. First, there is a small latch on both sides that you need to push down before pulling the front cover towards you that release the clips holding the front cover in place. Pull only slightly forward because… Second, in the front cover there are 6 circular notches connected to the front cover in tue four corners including the middle corners, you need to squeeze the front cover a little bit gently removing the notches so they dont break (like mine did).
    ralphkeneth_gomz - Antwoord
    Definitely had to watch about 10 videos and still couldn’t get it to pop out easily.. Took a look at the first picture in the next step and really took note of where the little hole that lets you through to push down the tab is. Once I took a look at that and combined the techniques I’d seen in some of the videos it finally popped off easily. https://www.youtube.com/watch?v=u7i0_nD9... I only watched the first minute of this video but it helped a good bit if anyone else is having trouble.
    Rowan Darko - Antwoord
    How do you know if the speakers or one of them is burned or broken.. i notice that one speaker is playing much less hard then the other one.. I wonder now if maybe there is another problem with my device.. Battery problem?
    Bukowski101 - Antwoord
  2. JBL Charge 3 luidspreker vervangen: stap 2, afbeelding 1 van 1
    • Trek de voorkant aan beide kanten voorzichtig uit elkaar en verwijder deze van de luidsprekerbehuizing.
    • De binnenkant van de voorklep heeft gaten die moeten overeenkomen met de bijbehorende pinnen op de luidsprekerbehuizing voor een juiste montage.
    • Het verwijderen van de voorklep heeft geen invloed op de waterdichte afdichtingen van het apparaat. Voor het verwijderen van en verdere demontage van uw luidspreker moeten waterdichte afdichtingen en pakkingen worden verwijderd. Uw apparaat is mogelijk niet meer waterdicht nadat deze zijn gewijzigd.
    Include dissembling the plastic cover? cover?
    KanGoon - Antwoord
    @KanGoon Yes, on mine it took the removal of 6 (reasonably obvious) screws to remove that. I’ll try to insert a photo when I reassemble…
    Very good guide! Pics and descriptions make this easy!
    John G Petko - Antwoord
    There is a step missing here. How do you remove the rubber cover that covers the port?
    Phillip Luebke - Antwoord
    Gibt es eine Möglichkeit diese wieder wasserdicht zu bekommen?
    Furkan Karakelle - Antwoord
    Well, broke off the cover tabs. Have to remove 2 screws first. Might add that to the instructions.🤔
    Spartacus - Antwoord
    Me too. Saw the screws after I'd popped it off.
    Del Taylor -
    It doesn't look fixable. Can't get the cover to stay on anymore. Ideas?
    Del Taylor - Antwoord
  3. JBL Charge 3 luidspreker vervangen, Luidspreker: stap 3, afbeelding 1 van 2 JBL Charge 3 luidspreker vervangen, Luidspreker: stap 3, afbeelding 2 van 2
    • Verwijder de acht 10 mm Phillips #1-schroeven rond de twee voorluidsprekers.
    Die Frage : Ist ob man irgendwo Ersatz Lautsprecher bekommt ???
    nicowihnaleck - Antwoord
    Probier's mal hier, vergleiche aber ganz genau (Seriennummer GG…):
    https://ecommerce.mysav.eu/en/jbl/147-sp...
    VauWeh - Antwoord
  4. JBL Charge 3 luidspreker vervangen: stap 4, afbeelding 1 van 1
    • Trek voorzichtig aan een van de luidsprekers zodat deze zich buiten de behuizing bevindt. Wees voorzichtig, want deze is nog steeds met de draden aan het moederbord bevestigd.
  5. JBL Charge 3 luidspreker vervangen: stap 5, afbeelding 1 van 3 JBL Charge 3 luidspreker vervangen: stap 5, afbeelding 2 van 3 JBL Charge 3 luidspreker vervangen: stap 5, afbeelding 3 van 3
    • Druk met een kruiskopschroevendraaier #000 op het kleine metalen lipje op de luidsprekerconnector en trek de connector voorzichtig uit elkaar.
    • Markeer de draden met L (Links) en R (Rechts), zodat je tijdens de montage weet welke connector waar zit
    Where can l buy those speaker for replacing
    Terrence Terrence - Antwoord
    Somebody know where I can buy These speakers ?
    motje - Antwoord
    The speakers that is on my charge 3 is soldered on doesn’t have the clips in picture
    travenature - Antwoord
  6. JBL Charge 3 luidspreker vervangen: stap 6, afbeelding 1 van 1
    • Herhaal de vorige stap voor de tweede connector.
  7. JBL Charge 3 luidspreker vervangen: stap 7, afbeelding 1 van 2 JBL Charge 3 luidspreker vervangen: stap 7, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Pak de gebundelde kabelconnector die de luidsprekers met het moederbord verbindt met een pincet. Trek de connector voorzichtig los.
  8. JBL Charge 3 luidspreker vervangen: stap 8, afbeelding 1 van 1
    • Nu de tweede luidspreker is losgekoppeld van het moederbord, trek je de luidspreker en de draden uit de behuizing.
    where can i buy these speaker,i need to replace the left side speaker because it was already damaged
    geoffrey mustar - Antwoord
Conclusie
Volg deze instructies in omgekeerde volgorde om je apparaat weer in elkaar te zetten.
45 andere personen hebben deze handleiding voltooid.
Met dank aan deze vertalers:
en nl
100%
Deze vertalers helpen ons de wereld te repareren! Wil je bijdragen?
Begin met vertalen ›
Aidan Hays
4.050 Reputatie
2 handleidingen geschreven
Cal Poly, Team S13-G1, White Fall 2018 Lid van Cal Poly, Team S13-G1, White Fall 2018
CPSU-WHITE-F18S13G1
3 Leden
26 handleidingen geschreven
32Gids Commentaar
Where I can buy the same jbl speaker ?
Ekinox - Antwoord
I need to replace my JBL charge 3 speaker
Lara Esther -
Where can buy the small speakers? Helpp
Luis Cilia - Antwoord
I have to pull out the motherboard to get those speakers out.
Tr0ll05aur0s 3z - Antwoord
where can i buy the replacement speakers?
Yhamani Pangarungan - Antwoord
Mine did not have the little clips in step 5. It was just soldered on. I ended up removing it from the other end. At the little white clip that goes in the motherboard (shown in step &) I was able to remove the pin. by pressing down on the top where you can see the silver.
Mike - Antwoord
It doesn’t seem possible to buy replacement speaker units.
dave - Antwoord
I see them on ebay, there are two designs. Btw, my speakers don't have clips, they are soldered on.
Erwin Johnson - Antwoord
i just completed this repair using generic replacement speakers from ali express item number 32829635211
mine were soldered on. i had to trim 4 orientation posts that prevent the factory speakers being installed rotated incorrectly, as these wouldn’t work with the new speakers. they sound OK, but have noticeably less bass than the OEM JBL drivers and can sound a little more tinny. there are also people doing it on ebay for 30$, but i am not in the USA so that was not convenient.
ivan@absolutehid
ivan - Antwoord
Where can I buy these same speakers
Silvester Whitehurst - Antwoord
San mkabili ng orig.na speaker ng jbl3?
rodolfom.afan - Antwoord
where I can buy these speakers. also need it for India region . but as I checked not able to buy it .
Prince Gupta - Antwoord
Contact JBL customer service if y3have or gen get the teveipt call them and then email pic8or the receipt ant the JBL Serial number by the speakers when the blabk jbl grill is off if less than 12 months old youll get a free speaker replacement if out warranty or you have no receipt the replacement speaker for Charge3 is only $32.19 USD. Good luck.
David Lorince - Antwoord
Contact JBL customer service if you have a charge 3. get the customer service number, call them and or then just email description fate SN# and pic of the receipt and the JBL Serial number between the speakers when the black JBL grill is off, but only if its less than 12 months old then you’ll get a free speaker replacement if out warranty or you have no receipt the replacement speaker for it is cheap only the JBL Charge3 is only $32.19 USD. Good luck.
If you can find a cheap replacement battery for $20 grab it cause its totally worth it if out in the wilderness it also acts as a cellphone charger.
Fyi upset neighbors since my left charge 3 is blown i decided it daisy chain 3 50 wayt pyle horn tweeters omg lets just day its about 500p% louder. Lol. Happy 4th of
Do you have a specific link for this OEM JBL charge 3 speaker replacement or are you just directing us to the JBL company where they currently want $35 + shipping on a single speaker unless the Charge 4 and Flip 4 lower these crazy prices. Has any one found a similar Charge 3 speaker replacement that’s louder and cheaper ???
For anyone that is wondering where to buy the speaker replacement, you can find it on all express just search up JBL charge 3 speaker replacement.
Armin Aghayan - Antwoord
Absolutely ridiculous how much replacement speakers are! I found some that “work” but they sound like crap…… Considering I have 4 Charge3’s and 1 Charge4, Harmon already has PLENTY of my $$!
Sheldon Abbey - Antwoord
JBL Charge 3 -
vorrei acquistare la coppia di casse uguale modello e dimensioni potreste fornirmi l’articolo a il link x ordinarli grazie
I would like to purchase the pair of speakers of the same model and size, could you provide me with the article at the link to order them, thank you
roberto - Antwoord
Ciao @flipok ! Maybe you can find some options in this Answer on our Forum: Where to buy replacement speakers for JBL Charge 3? Good luck!
Claire Miesch -
In accurate info unless they change how they put it together later down the road
Yeah, you typically do everything in reverse.
P C -
good dayhouse pls where can i buy replacement speaker for jbl charge 3 and battery any body with information thanks
EMMANUEL JUNIOR - Antwoord
I've ordered one. I will update after installation is done.
Rich Buffetta - Antwoord
Simple install. Youll need a soldering iron, some solder and a smallish phillips. Works fine now for about 10 bucks from ali.
Rich Buffetta -
Amazon, JBL.Com, Ebay.. Search for OEM JBL Charge 3 replacement speaker. Very easy.
Original speaker parts can be obtained in the UK by contacting Multicare Electronics ( +441132791255 , info@multicare.org.uk ). I initially called the Harman support line (Harman is the umbrella company of JBL), who redirected me to Multicare who are their official repair/parts company in the UK. Multicare sent me a replacement speaker unit for about £20 (ex shipping), which I have now fitted and is working perfectly. Good experience and thanks for this iFixit guide!
nixrushperseus - Antwoord
I got my Charge 3 used, and apparently abused. Right speaker has pin holes in the cone; left speaker missing...
My question is why would anyone ground the + input to the speakers? Both are connected to the speaker inputs and also grounded to the speaker frame...
Thanks
Perry Thompson - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 17
Afgelopen 7 dagen: 140
Afgelopen 30 dagen: 704
Altijd: 97,386
