Ga door naar hoofdinhoud
Ivation IVWPDC20Y Display Replacement
Wat je nodig hebt
    1. Ivation IVWPDC20Y Display Replacement, Display: stap 1, afbeelding 1 van 1
      • With the H2.0 bit screwdriver, remove the two screws on the yellow waterproof cover
      Vraag FixBot
      Voeg opmerking toe
    2. Ivation IVWPDC20Y Display Replacement: stap 2, afbeelding 1 van 1
      • Apply a plastic opening tool to each of the corners and gently remove the casing
      • The front casing is held down by adhesive and may require additional work to remove
      • Apply just enough force to undo the inner latches to make sure not to damage the waterproof seal
      Vraag FixBot
      Voeg opmerking toe
    3. Ivation IVWPDC20Y Display Replacement: stap 3, afbeelding 1 van 1
      • Remove the five silver screws from the inner casing using the PH00 screwdriver bit.
      Vraag FixBot
      Voeg opmerking toe
    4. Ivation IVWPDC20Y Display Replacement: stap 4, afbeelding 1 van 1
      • Remove the six screws from the edge of the clear inner casing with the PH00 screwdriver bit.
      • These screws are very small and easy to strip so apply consistent pressure when removing them
      Vraag FixBot
      Voeg opmerking toe
    5. Ivation IVWPDC20Y Display Replacement: stap 5, afbeelding 1 van 1
      • Pry off back outer casing using the black spudger or the blue prying tools.
      Vraag FixBot
      Voeg opmerking toe
    6. Ivation IVWPDC20Y Display Replacement: stap 6, afbeelding 1 van 1
      • Carefully remove the screen from the silver casing using a prying tool or the black spudger.
      • There is adhesive in the center of the screen, be sure not to bend it when applying pressure.
      Vraag FixBot
      Voeg opmerking toe
    7. Ivation IVWPDC20Y Display Replacement: stap 7, afbeelding 1 van 1
      • Using the poker end of the spudger push gently on the black pegs holding the orange tape in place.
      • Screen and orange tape should slip out as a whole.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Alex
228 Reputatie
2 handleidingen geschreven
USF Tampa, Team 6-6, Eyestone Spring 2016 Lid van USF Tampa, Team 6-6, Eyestone Spring 2016
USFT-EYESTONE-S16S6G6
3 Leden
40 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 20
Altijd: 637
