Ga door naar hoofdinhoud
Ion Air Pro Body Cover Replacement
Wat je nodig hebt
    1. Ion Air Pro Body Cover Replacement, Body Cover: stap 1, afbeelding 1 van 1
      • Unscrew all six screws.
      • Make sure you put the screws in a good spot where you won't lose them because they are small.
      Vraag FixBot
      Voeg opmerking toe
    2. Ion Air Pro Body Cover Replacement: stap 2, afbeelding 1 van 1
      • After you're done with unscrewing, take off the blue lid shown here.
      Vraag FixBot
      Voeg opmerking toe
    3. Ion Air Pro Body Cover Replacement: stap 3, afbeelding 1 van 1
      • On the other side of the device, lift this black piece of cover that is underneath the cap, on the bottom side of the Ion Air Pro.
      Vraag FixBot
      Voeg opmerking toe
    4. Ion Air Pro Body Cover Replacement: stap 4, afbeelding 1 van 1
      • After removing the black lid, unscrew all eight screws here.
      • Again, make sure you keep track of your screws and don't lose them.
      Vraag FixBot
      Voeg opmerking toe
    5. Ion Air Pro Body Cover Replacement: stap 5, afbeelding 1 van 1
      • Remove two more screws, one on each side, inside this socket.
      Vraag FixBot
      Voeg opmerking toe
    6. Ion Air Pro Body Cover Replacement: stap 6, afbeelding 1 van 1
      • Next, unscrew the two screws located here.
      Vraag FixBot
      Voeg opmerking toe
    7. Ion Air Pro Body Cover Replacement: stap 7, afbeelding 1 van 1
      • Detach the bottom black piece off from the bottom side but do not disconnect it from the wires.
      • Everything inside is still connected with all the wires, so be careful not to pull too hard or else everything inside could fall out or get broken.
      Vraag FixBot
      Voeg opmerking toe
    8. Ion Air Pro Body Cover Replacement: stap 8, afbeelding 1 van 1
      • Finally, you can remove the body cover off and replace it with a new one if you have to.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Christopher Brandl
673 Reputatie
5 handleidingen geschreven
UW Stout, Team S6-G2, Ogden Fall 2018 Lid van UW Stout, Team S6-G2, Ogden Fall 2018
UWSTOUT-OGDEN-F18S6G2
4 Leden
5Gids Commentaar
Hey Chris where can I buy a replacement body cover?
The thread of the screw socket on my ion air pro WiFi has worn out and it can no longer be screwed onto any mounts.
Sam s - Antwoord Deel
I LOST THE LOSTTHE REAR COVER WHILE HUNTING. iS THERE A REPLACEMENT I CAN GET
mcbee1010 - Antwoord Deel
i lost the rear cover cap while hunting. can i purchase a new one
Can you show a photo of the other side (compared to step 8) showing the mounting thread please?
Andrew Mawby - Antwoord Deel
Help: How to replace the battery, mine won't charge?
Kevin Harmon - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 36
Altijd: 1,149
