Ga door naar hoofdinhoud
Iomega MiniMax Disassembly
Wat je nodig hebt
      • Before you begin:
      • If your disk is mounted and running, be sure to eject it from your desktop.
      • Turn power off via the physical switch on the rear of the enclosure.
      • Remove all cables from the rear of the device. Make note of which cables were used in which ports if you have multiple devices and may mix them up. It's best to use the exact same ports to eliminate any potential issues in case you have a bad port.
      Vraag FixBot
      Voeg opmerking toe
    1. Iomega MiniMax Disassembly, Remove screws.: stap 2, afbeelding 1 van 1
      • On the rear of the device, remove the 2 philips screws, with a small screwdriver. Screws are both the same.
      • (Sorry for the poor quality photos.)
      Vraag FixBot
      Voeg opmerking toe
    2. Iomega MiniMax Disassembly, Loosen upper case.: stap 3, afbeelding 1 van 2 Iomega MiniMax Disassembly, Loosen upper case.: stap 3, afbeelding 2 van 2
      • Using a thin rigid tool (or old credit card), start on the rear, wedge it into the gap between the upper and lower cases as shown.
      • Slowly work your way around the device while gently pulling up on the separating cover.
      • Make sure to use care near the rear center, to avoid breaking a single center tab at this location. By the time you get to the front, the upper case should almost be falling off, and can be easily removed.
      Vraag FixBot
      Voeg opmerking toe
    3. Iomega MiniMax Disassembly, Remove upper case.: stap 4, afbeelding 1 van 3 Iomega MiniMax Disassembly, Remove upper case.: stap 4, afbeelding 2 van 3 Iomega MiniMax Disassembly, Remove upper case.: stap 4, afbeelding 3 van 3
      • Remove upper case. One each of the Left, Front, and Right sides, you can see 3 tabs (per side), that were holding the case on. On the rear you will see the fragile clip that should be removed last, if possible.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
13 andere personen hebben deze handleiding voltooid.
scottbernardis
1.082 Reputatie
1 Handleiding geschreven
7Gids Commentaar
EXACTLY what I was seeking!
kend - Antwoord Deel
Thanks for the tip! What kind of internal bus does the drive use, should I want to upgrade it?
Mariano B. - Antwoord Deel
No idea on the internal bus. Not my area of expertise.
scottbernardis - Antwoord Deel
The hardest part was finding an old credit card! BTW, the hard drive in my unit is a 2TB Seagate Barracuda LP with a SATA interface. I’m considering replacing it with a SSD.
Jon Noxon - Antwoord Deel
This is exactly what I was looking for. I have an old one that stopped working and I want to replace the drive.
Noah Preston - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 60
Altijd: 7,869
