Ga door naar hoofdinhoud
Installing MacBook Pro 13" Unibody Mid 2009 Dual Hard Drive
Wat je nodig hebt
  1. Installing MacBook Pro 13" Unibody Mid 2009 Dual Hard Drive, Remove the lower case screws: stap 1, afbeelding 1 van 1
    • Remove the following 10 screws securing the lower case to the MacBook Pro 13" Unibody:
    • Seven 3 mm Phillips screws.
    Compare the short screws carefully before reinstalling them. The shouldered screws go in the holes on the front edge.
    David Kilbridge - Antwoord
    Before I started removing any screws I took a piece of paper and drew the bottom of the laptop and put a piece of double-sided tape in the spot where each screw goes. That way when I took out the screws, I could put them on the tape so I knew exactly which screw went in which spot. I did the same thing for dismantling the inside on another sheet of paper, then a third sheet for the screen after getting the front glass off.
    mastover - Antwoord
    I use a similar technique: I print out the iFixit manual for the job, and Scotch-tape down the screws/brackets/cables I remove at each step next to the component descriptions. That way, when I'm reassembling, the bits are taped right next to the photo of where they came from.
    adlerpe -
    That's exactly what I do for all my repairs! It's the best way to keep track of all of the parts ' original location and to make sure that you don't miss any parts during reassembly.
    joyitsjennie -
    Great idea and one I use often
    Thomas Overstreet -
    Excellent idea! Thanks for sharing it here.
    Laura Sharkey -
    I used a 00 that fit but the screws were very tight so I used a tiny paintbrush with some wd40 on it and put it around the edges of the screws. Worked like a charm
    valentinedhdh - Antwoord
    I use a magnetic mat and place the screws in order on that :)
    Cary B - Antwoord
  2. Installing MacBook Pro 13" Unibody Mid 2009 Dual Hard Drive, Lift the lower case away: stap 2, afbeelding 1 van 1
    • Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
    In the introduction you should link fixers to this excellent doc: https://www.ifixit.com/Misc/HD_Software_...
    It is really critical, super easy, and free(!) to clone your existing drive onto the new one you will install. I ran into one error, but SuperDuper! support replied immediately on how to fix it...Thanks ifixit and SuperDuper! (I ponied up the $28 for the software anyway, I was so impressed!)
    Mike - Antwoord
    Long story short: I drank the AppleKoolAid back in 1984 and have always left the guts of my machines up to Apple - until recently when I needed to swap the SATAs from my original MacDaddy (2009 13" MBPro that I killed in 2018 - coffee + blackout = OOOOPS) into a pristine 2009 MBPro from a Goodwill in North Carolina through eBay. I need the files from iCal and MacMail that can't be opened in my newer machines.
    Well . . . I ain't never done nuttin' like that, before!
    Enter Luke Miani on YouTube. He raves about you guys! So, I watched everything I could, read your site, bought the right tools and at the ripe old age of 72, I sat down, this morning and did the work. Now my original MacDaddy lives in MacDaddy2.0.
    Am I allowed to cry?
    Seriously, I can't thank you enough for your bitchen site and killer tools. I wish I'd'a been turned on to this shizzle 30+ years ago.
    IFIXIT - IDIGIT!
    kath myers - Antwoord
    HAHAHAHAHAHAHAHAHAHA.
    That was a brilliant read.
    Yes, I came across ifixit a few years ago. Totally helped me out on several occasions.
    Glad your Mac repair journey worked out.
    Cary B -
  3. Installing MacBook Pro 13" Unibody Mid 2009 Dual Hard Drive, Battery: stap 3, afbeelding 1 van 1
    • For precautionary purposes, we advise that you disconnect the battery connector from the logic board to avoid any electrical discharge.
    • Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
    Citaat van gansodesoya:
    why is step 3 necessary?
    Just to disconnect any power source to avoid damages by short-circuits.
    MrKane - Antwoord
    How do you get that battery connector back on? Do you just press it in back in place after you're done?
    Horace Chung - Antwoord
    yes. I usually plug it in before I screw it down so I can lift the battery a bit and have enough slack to be able to go straight down on the connector, otherwise it comes in on a bit of an angle, which can't be good (though not necessarily bad).
    maccentric -
    This step almost finished me, and I did extensive damage to the battery plug. Fortunately, I later replaced the battery, and the replacement came with a new plug! :) Newbies need to know - 1. The battery plug is like a thin lip on a thicker lip, so you need to pry BETWEEN 2 thin lips to get it off, else you are trying to yank out the socket. 2. Mine was initially VERY tight, and trying to get it out broke the plastic on all sides of plug, even though I was as careful as possible. Luckily, this didn't hurt functionality and I later replaced the battery. AFTER disconnecting once, it was never so tight again,
    Jeff Diamond - Antwoord
  4. Installing MacBook Pro 13" Unibody Mid 2009 Dual Hard Drive, Optical Drive: stap 4, afbeelding 1 van 1
    • Using the flat end of a spudger, gently pry the right speaker/subwoofer cable connector straight up off the logic board. Be careful not to lift the socket. Pull the connector toward the optical drive.
    • Pry up from beneath the wires.
    Step 4 is correct as stated (pull up, not slide out). You'll definitely see this when you put it back in place, pushing down in socket not sliding in. Just be careful and use spudger (gently!) underneath wires as shown.
    jgcolt - Antwoord
    What is the best way to solder this back onto the board? I did it once 5 years ago, but that was my first and only time soldering. I know there is a soldering guide, and I have read it. Could someone tell me please the best way to reconnect the right speaker/subwoofer cable to the board, referencing the soldering guide?
    Leslie L. Gordon - Antwoord
  5. Installing MacBook Pro 13" Unibody Mid 2009 Dual Hard Drive: stap 5, afbeelding 1 van 1
    • It will be necessary to slide the small clear plastic cable retainer (boxed in red) glued to the logic board out of the way before disconnecting the camera cable. Be careful not to break any components off the board as you slide it away from the camera cable connector.
    • Pull the camera cable connector toward the optical drive to disconnect it from the logic board.
    • This socket is metal and easily bent. Be sure to align the connector with its socket on the logic board before mating the two pieces.
    When you put the Mac back together after this entire procedure, it's virtually impossible to get the camera cable reconnected because there is a small piece of plastic glued to the board to keep it from coming unplugged. An Apple store tech explained the piece of plastic and said it won't break anything if I pry it off the board. I did and then the cable connected easily.
    karenz - Antwoord
    The retainer for the camera cable may be black as well as clear. It is much easier to remove and reinstall the retainer if the DVD drive cable is removed first.
    MikeG - Antwoord
  6. Installing MacBook Pro 13" Unibody Mid 2009 Dual Hard Drive: stap 6, afbeelding 1 van 1
    • Use the flat end of a spudger to pry the optical drive connector straight up off the logic board.
  7. Installing MacBook Pro 13" Unibody Mid 2009 Dual Hard Drive: stap 7, afbeelding 1 van 1
    • Use the flat end of a spudger to pry the hard drive connector straight up off the logic board.
  8. Installing MacBook Pro 13" Unibody Mid 2009 Dual Hard Drive: stap 8, afbeelding 1 van 1
    • Remove the two Phillips screws securing the subwoofer to the upper case. The right one is 5 mm and the left 3.9 mm.
    • The longer of the two screws is on the right.
    For step 8, I found I had to use a Phillips #0 screwdriver to remove the two screws. I'm not sure if mine were just over-tightened, but I couldn't get the two screws off with a cheapo Radioshack #00 screwdriver or a nice Wiha one for the life of me without coming close to stripping them. Tried the #0 and they popped right out. Hope this helps.
    Aaron B - Antwoord
  9. Installing MacBook Pro 13" Unibody Mid 2009 Dual Hard Drive: stap 9, afbeelding 1 van 2 Installing MacBook Pro 13" Unibody Mid 2009 Dual Hard Drive: stap 9, afbeelding 2 van 2
    • The subwoofer is still connected to the right speaker, so don't completely remove it just yet.
    • Lift the subwoofer off the optical drive, and set it above the computer.
  10. Installing MacBook Pro 13" Unibody Mid 2009 Dual Hard Drive: stap 10, afbeelding 1 van 2 Installing MacBook Pro 13" Unibody Mid 2009 Dual Hard Drive: stap 10, afbeelding 2 van 2
    • Remove the two 8.4 mm Phillips screws securing the camera cable bracket to the upper case.
    • The right screw may remain captive in the camera cable.
    • Lift the camera cable bracket out of the upper case.
    There's another type of bridge, black, with an extra piece of metal to hold the cable. You don't have to remove this bridge to unmount the optical drive.
    Martin - Antwoord
  11. Installing MacBook Pro 13" Unibody Mid 2009 Dual Hard Drive: stap 11, afbeelding 1 van 2 Installing MacBook Pro 13" Unibody Mid 2009 Dual Hard Drive: stap 11, afbeelding 2 van 2
    • Remove the three 2.5 mm Phillips screws securing the optical drive to the upper case.
    • Lift the optical drive from its right edge and pull it out of the computer.
  12. Installing MacBook Pro 13" Unibody Mid 2009 Dual Hard Drive, Optical Drive: stap 12, afbeelding 1 van 1
    • Remove the optical drive cable by pulling it straight away from the optical drive.
    • This connector is particularly deep, so be sure to pull away from the drive at the center of the connector.
    • If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
  13. Installing MacBook Pro 13" Unibody Mid 2009 Dual Hard Drive: stap 13, afbeelding 1 van 1
    • Remove the two black Phillips #0 screws securing the small metal mounting bracket. Transfer this bracket to your new optical drive or hard drive enclosure.
  14. Installing MacBook Pro 13" Unibody Mid 2009 Dual Hard Drive, Dual Hard Drive: stap 14, afbeelding 1 van 2 Installing MacBook Pro 13" Unibody Mid 2009 Dual Hard Drive, Dual Hard Drive: stap 14, afbeelding 2 van 2
    • Remove the plastic spacer from the optical bay hard drive enclosure by pressing in on one of the clips on either side and lifting it up and out of the enclosure.
    is it 9,5mm or 12,7mm for the caddy? My stuff macbook pro mid 2010, need advice what size is compatible. Thank you
    Adi Purba - Antwoord
    All Macbooks use 9.5mm Optical Drive Caddy, also, If you’re wondering as well, the Optical Drive runs at SATA II speeds just like with the main hard drive area, so if you’re using a SSD, then it’s going to run at a slightly slower speed.
    - PS5iscool - - Antwoord
  15. Installing MacBook Pro 13" Unibody Mid 2009 Dual Hard Drive: stap 15, afbeelding 1 van 3 Installing MacBook Pro 13" Unibody Mid 2009 Dual Hard Drive: stap 15, afbeelding 2 van 3 Installing MacBook Pro 13" Unibody Mid 2009 Dual Hard Drive: stap 15, afbeelding 3 van 3
    • Make sure that the hard drive connectors are facing down before placing it into the enclosure.
    • Gently place the hard drive into the enclosure's hard drive slot.
    • While firmly holding the enclosure in place with one hand, use your other hand to press the hard drive into the enclosure connectors.
    Okay it seems like some models of MacBook Pro have issues with a fast (6Gbit/s) SSD in the optical bay. Even though my Mac says it offers 6Gbit on both bays it simply didn't work in the optical bay. So I switched places between the two drives and everything seems to work. My Mac booted from the old HDD in optical bay automatically and then I cloned it afterwards and changed the startup disk to the new one. As said before, don't put a fast SSD in the optical bay!
    Carl - Antwoord
    This is an extremely late response to an old comment, but… whatev’s. My 2011 MacBook Pro had that issue: the main (HDD bay) SATA operated at 6Gbit, and while the optical bay said it was 6Gbit, the “Negotiated Link Speed” was like 1.5Gbits regardless of what you put in it (I can understand 1.5Gbits for an optical drive, but not for an SSD). Some of the early 2012 models did the same thing, from what I understand, but that was corrected pretty early on; both my 13” and 15” 2012’s run at 6Gb/s on both SATA busses.
    AJH -
    It’s not wise to swop the optidrive for an HD as there is no physical protection. The caddy is only intended for an SSD.
    Ben Ormerod - Antwoord
  16. Installing MacBook Pro 13" Unibody Mid 2009 Dual Hard Drive: stap 16, afbeelding 1 van 2 Installing MacBook Pro 13" Unibody Mid 2009 Dual Hard Drive: stap 16, afbeelding 2 van 2
    • Once the hard drive is snug, reinsert the plastic spacer while holding the hard drive against the bottom of the enclosure.
    Normally with the HD enclosure there come a set of screws. use these to screw down the HD in the enclosure since you need to flip it up side down to reinstall it into the MBP
    Bart - Antwoord
  17. Installing MacBook Pro 13" Unibody Mid 2009 Dual Hard Drive: stap 17, afbeelding 1 van 2 Installing MacBook Pro 13" Unibody Mid 2009 Dual Hard Drive: stap 17, afbeelding 2 van 2
    • Use two Phillips #1 screws to secure the drive to its enclosure.
    Where are these screws coming from? Were they part of the original optical drive?
    Bradley DeHerrera - Antwoord
    The new enclosure should include these two Phillips screws.
    Sam Omiotek -
    Can someone show the step of removal process of hdd/SSD placed in the caddy? I am unable to revert this process. Do we have to apply back greater force to remove back the hard drive/SSD from the caddy?
    Tarun Kumar Verma - Antwoord
    Gads, I wish they made a caddy where the optical drive was removable without having to remove the entire caddy. That is a major peeve of mine. Like… just mount it the other way! I don’t want to have to go through this entire process every time I upgrade the secondary drive.
    AJH - Antwoord
    These screws seems to be located in different places on different enclosures. I had serious trouble getting the SSD that the previous owner of this MacBook installed out of the enclosure until I realized the screws holding the SSD in place were on the side and not on the bottom. In case anyone else has the same issue!
    nessie1001 - Antwoord
  18. Installing MacBook Pro 13" Unibody Mid 2009 Dual Hard Drive: stap 18, afbeelding 1 van 1
    • Attach the optical drive bracket to the new enclosure with two Phillips #0 screws.
    • Reconnect any cables you have removed from the original optical drive onto the optical bay enclosure.
    Replaced the optical with hdd, as well as replaced the hard drive with an ssd. Now I get the circle with a line through it. But, when I hold the option key down, it gives me both hard drives, PLUS, the thumb drive I have in the USB port with a Mountain Lion installer. It even shows the recovery disks, but gives me the circle with the line when I choose one. Any help is appreciated.
    claude - Antwoord
    Mate,
    My mbp shipped with OS 10.8, and I had upgraded twice to 10.10
    I've a 10.7 USB which upgraded my old MBP.
    My plan today was to boot with my new ssd, my time machine back up and the Lion usb plugged in.
    I would then click on the Lion usb, and tell it to put the OS and time machine back up on the ssd.
    So I help down ALT and when it started it gave me the options of the usual Mac internal or the Lion USB.
    I clicked Lion, but instead of taking me to the install options (Disk utility, restore from time machine etc etc) it gave me that grey circle with a diagonal line through it. The no entry sign - grey on grey - that I think you have.
    Some googling said that it is because I was trying to usb a 10.7 install on a MBP that shipped 10.8
    You can't go back, apparently.
    So if any of the OSs are older than the mac you got, you will get this error. The grey in grey no entry.
    I just cloned my HDD to my ssd (Carbon copy cloner free 30 day trial) using an external stat-usb3 wire and all is good.
    Rory -
    I have a 17" Macbook Pro6,1 unibody with an Intel Core i5, 2.53GHz. I was successful installing a 250GB SSD in the DVD bay, and I'm able to boot from it. I did this by first installing OS X 10.9.4 on the SSD mounted into an external HD case, testing the system to see if it would boot up into the SSD, then installing the SSD and carrier in the DVD drive bay. The system now boots up from the SSD with no problems. If you are having installation problems, I recommend trying this method.
    roger hall - Antwoord
    I just have finished installing second SSD to my MBP (unibody 15` 2010).
    First one was changed like one year ago. Samsung 500GB SSD. It is in my HDD bay and I'm running system from it.
    Today I put a new Samsung 1TB 850 Evo 1 SSD in to my optic bay.
    I encounter problem with SSD not recognized by Finder.
    But It was recognized by Disk Utility.
    What I did was I erase new SSD by Disk Utility. Then the new partition was created and now It has been seen by Finder.
    So If you see it in Disk Utility just erased it.
    Some extra info in under this link--> https://discussions.apple.com/docs/DOC-4...
    Wish you all luck :)
    rybafly - Antwoord
    My installation went great thanks to the guide. I did notice a small thing that might make a good tip, and that is to inspect all the visible screws. I saw one that was slightly raised, and when I poked around with the spudger, I found 2 more that had worked themselves out a bit. Its probably something super rare but at the age of these things, it wouldn't hurt to check.
    Tineyi Chapisa - Antwoord
  19. Installing MacBook Pro 13" Unibody Mid 2009 Dual Hard Drive: stap 19, afbeelding 1 van 3 Installing MacBook Pro 13" Unibody Mid 2009 Dual Hard Drive: stap 19, afbeelding 2 van 3 Installing MacBook Pro 13" Unibody Mid 2009 Dual Hard Drive: stap 19, afbeelding 3 van 3
    • Don't ditch that drive! You can still use your optical drive externally with the help of our SATA Optical Drive USB Cable.
    • Align the cable's SATA connector with the drive's port and plug in securely.
    • Plug the USB connector into your laptop and your optical drive is ready for use.
    There is a small metal button in the front of the drive and you can use that to eject the drive if you were wondering.
    Joseph Landry - Antwoord
    Maybe that explain the eject button mechanism maybe….
    Die neue SSD wurde durch das Laufwerk ersetzt aber leider wird jetzt die alte HDD nicht mehr erkannt. Hatte schon ein anderer das Problem?
    Alexander Richter - Antwoord
Conclusie
137 andere personen hebben deze handleiding voltooid.
Jake Devincenzi
117.301 Reputatie
57 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 84
Altijd: 119,047
