Ga door naar hoofdinhoud
Inspiron 7359 2-in-1 Fan Replacement
Wat je nodig hebt
  1. Inspiron 7359 2-in-1 Fan Replacement, Disassembling the Inspiron 7359 2-in-1: stap 1, afbeelding 1 van 1
    • Turn off device before starting.
    • Turn the laptop upside down with the logo facing the surface of the table.
  2. Inspiron 7359 2-in-1 Fan Replacement: stap 2, afbeelding 1 van 2 Inspiron 7359 2-in-1 Fan Replacement: stap 2, afbeelding 2 van 2
    • Use a Phillips #0 screwdriver to remove the ten 8mm screws from the back case of the laptop.
  3. Inspiron 7359 2-in-1 Fan Replacement: stap 3, afbeelding 1 van 1
    • Use a spudger to separate the back cover from the laptop.
    • Start from one corner and work your way around the edge of the cover.
    • Be careful not to bend or crack the back cover.
  4. Inspiron 7359 2-in-1 Fan Replacement: stap 4, afbeelding 1 van 1
    • All hardware components should be exposed.
  5. Voorzichtig: stappen 5-6 komen van een handleiding die in bewerking is.
    Inspiron 7359 2-in-1 Fan Replacement, Hard Disk Drive: stap 5, afbeelding 1 van 1
    • Unscrew three 3mm screws with a Phillips #0 screwdriver and remove them.
    • These screws hold the hdd and removing these screws will make it easier to remove it.
  6. Inspiron 7359 2-in-1 Fan Replacement: stap 6, afbeelding 1 van 2 Inspiron 7359 2-in-1 Fan Replacement: stap 6, afbeelding 2 van 2
    • Lift the hard drive from the left side. Be careful not pull on it.
    • Pull the SATA cable that's connect to the hard drive and then carefully place the cable on the side.
  7. Inspiron 7359 2-in-1 Fan Replacement, Fan: stap 7, afbeelding 1 van 2 Inspiron 7359 2-in-1 Fan Replacement, Fan: stap 7, afbeelding 2 van 2
    • Carefully pull the fan adapter labelled one.
  8. Inspiron 7359 2-in-1 Fan Replacement: stap 8, afbeelding 1 van 1
    • Pull the wire from the hook to make it easier to take the whole fan out.
  9. Inspiron 7359 2-in-1 Fan Replacement: stap 9, afbeelding 1 van 1
    • Remove one 5mm screw using the Phillips screw.
    • After the screw is extracted use your hands and carefully take the fan out.
Conclusie
Dominique
251 Reputatie
2 handleidingen geschreven
Gateway, Team S1-G3, Saknee Fall 2019 Lid van Gateway, Team S1-G3, Saknee Fall 2019
GCC-SAKNEE-F19S1G3
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 25
Altijd: 448
