Ga door naar hoofdinhoud
Insignia NS-HD01A Battery Replacement
Wat je nodig hebt
  1. Insignia NS-HD01A Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Remove the rubber screw caps using the pointed tip of the Spudger.
  2. Insignia NS-HD01A Battery Replacement: stap 2, afbeelding 1 van 1
    • Remove the four 6.0 mm Phillips screws located below the rubber caps using the PH00 bit installed in the driver.
  3. Insignia NS-HD01A Battery Replacement: stap 3, afbeelding 1 van 2 Insignia NS-HD01A Battery Replacement: stap 3, afbeelding 2 van 2
    • Use the plastic opening tool to pry open the back cover.
    • Slide the tool around the sides of the radio to gradually pry the back cover off. Do not remove the cover completely as there is still a cable connecting it to radio.
  4. Insignia NS-HD01A Battery Replacement: stap 4, afbeelding 1 van 3 Insignia NS-HD01A Battery Replacement: stap 4, afbeelding 2 van 3 Insignia NS-HD01A Battery Replacement: stap 4, afbeelding 3 van 3
    • Use the blunt tweezers to unplug the battery cable from the PCB board. Grab the battery cable plug from the sides.
  5. Insignia NS-HD01A Battery Replacement: stap 5, afbeelding 1 van 2 Insignia NS-HD01A Battery Replacement: stap 5, afbeelding 2 van 2
    • Use the flat side of the Spudger to pry the battery out of the back cover.
    • Insert the replacement battery into the back cover.
    • Reassemble the radio, making sure to reconnect the battery cable.
Conclusie
Joel Najmon
152 Reputatie
1 Handleiding geschreven
IUPUI, Team 2-2, Wilson Fall 2016 Lid van IUPUI, Team 2-2, Wilson Fall 2016
IUPUI-WILSON-F16S2G2
5 Leden
1 handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 18
Altijd: 1,034
