Inleiding
Is the power button no longer powering on your device? This guide will help replace the power button so you can turn your speaker on and off.
Wat je nodig hebt
Push the Spudger into the crevice between the grated panel of the speaker and the base of the speaker.
Angle the spudger to create a separation between the grate and the base.
Gereedschap gebruikt in deze stap:Tweezers$4.99
Using tweezers, detach the power button from the mother board.
