Ga door naar hoofdinhoud
Insignia NS-CLOPP2 Screen Replacement
Wat je nodig hebt
    1. Insignia NS-CLOPP2 Screen Replacement, Screen: stap 1, afbeelding 1 van 1
      • Turn the clock over and remove the 1cm screw with a Philips head screwdriver, which is located below the faceplate, on the bottom of the clock.
      Vraag FixBot
      Voeg opmerking toe
    2. Insignia NS-CLOPP2 Screen Replacement: stap 2, afbeelding 1 van 1
      • Begin to pry the front screen off gently with a Jimmy tool made by Ifixit.
      Vraag FixBot
      Voeg opmerking toe
    3. Insignia NS-CLOPP2 Screen Replacement: stap 3, afbeelding 1 van 1
      • Once you are able to create a space in between the device and the front screen, use your hands to continue to pry off the screen. Make sure that all the mini latches surrounding the perimeter have been unlatched, allowing the screen to come off easily.
      Vraag FixBot
      Voeg opmerking toe
    4. Insignia NS-CLOPP2 Screen Replacement: stap 4, afbeelding 1 van 1
      • Once you have undone the latches and pried off the first half of the screen, use your hand to pull off the rest of the screen.
      • To reassemble your device, follow these instructions in reverse order.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
Dilini De Silva
769 Reputatie
5 handleidingen geschreven
Marist, Team 1-1, Laflen Spring 2015 Lid van Marist, Team 1-1, Laflen Spring 2015
MARS-LAFLEN-S15S1G1
2 Leden
55 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 43
Altijd: 601
