Ga door naar hoofdinhoud
Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Insignia NS-CLIP02 Power Auxiliary Port Replacement Replacement
Wat je nodig hebt
  1. Insignia NS-CLIP02 Power Auxiliary Port Replacement Replacement, Power Auxiliary Port Replacement: stap 1, afbeelding 1 van 1
    • Locate the bottom of the device.
  2. Insignia NS-CLIP02 Power Auxiliary Port Replacement Replacement: stap 2, afbeelding 1 van 1
    • Begin by using a metal spudger to peel back the adhesive sticker and locate the 11mm screw beneath the sticker.
  3. Insignia NS-CLIP02 Power Auxiliary Port Replacement Replacement: stap 3, afbeelding 1 van 1
    • Locate the 11mm screw beneath the sticker.
  4. Insignia NS-CLIP02 Power Auxiliary Port Replacement Replacement: stap 4, afbeelding 1 van 1
    • Using a plastic spudger, peel off the adhesive gel stoppers.
  5. Insignia NS-CLIP02 Power Auxiliary Port Replacement Replacement: stap 5, afbeelding 1 van 1
    • Continue peeling the rest of the gel stoppers from the bottom of the device.
  6. Insignia NS-CLIP02 Power Auxiliary Port Replacement Replacement: stap 6, afbeelding 1 van 1
    • Begin unscrewing the six 11mm screws with a Phillips head screw driver.
  7. Insignia NS-CLIP02 Power Auxiliary Port Replacement Replacement: stap 7, afbeelding 1 van 1
    • Once you peel of the bottom from the device, you will see the motherboard.
  8. Insignia NS-CLIP02 Power Auxiliary Port Replacement Replacement: stap 8, afbeelding 1 van 1
    • Unscrew the 9.5mm screw located near the center of the motherboard with a Phillips head screw driver.
  9. Insignia NS-CLIP02 Power Auxiliary Port Replacement Replacement: stap 9, afbeelding 1 van 1
    • Lift the motherboard from the device.
  10. Insignia NS-CLIP02 Power Auxiliary Port Replacement Replacement: stap 10, afbeelding 1 van 1
    • Locate the four plugs connecting the motherboard to the rest of the device.
  11. Insignia NS-CLIP02 Power Auxiliary Port Replacement Replacement: stap 11, afbeelding 1 van 1
    • Begin with remove the plug to your left.
  12. Insignia NS-CLIP02 Power Auxiliary Port Replacement Replacement: stap 12, afbeelding 1 van 1
    • Remove the plug to your right from the motherboard.
  13. Insignia NS-CLIP02 Power Auxiliary Port Replacement Replacement: stap 13, afbeelding 1 van 1
    • Remove the plug in the front of the lcd screen plug.
  14. Insignia NS-CLIP02 Power Auxiliary Port Replacement Replacement: stap 14, afbeelding 1 van 1
    • Remove the LCD screen plug last. Then, follow the following instructions in reverse, replacing the old motherboard with the new one to fix the power auxiliary port.
Conclusie
Erik
405 Reputatie
4 handleidingen geschreven
USF Tampa, Team 9-3, Leahy Winter 2015 Lid van USF Tampa, Team 9-3, Leahy Winter 2015
USFT-LEAHY-W15S9G3
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 9
Altijd: 211
