Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Peel back the adhesive sticker using a metal spudger and remove the 11mm screw beneath the sticker with a Phillips head screw driver.
Using a plastic spudger, peel off the adhesive gel stoppers.
Unscrew the six 11mm screws with a Phillips head screw driver.
Remove the bottom of the device to reveal the motherboard.
Unscrew the 9.5mm screw located near the center of the motherboard with a Phillips head screw driver.
Lift the motherboard from the device and lie it face down. Beware of the cables plugged in on the back side
Remove the plug to your right from the motherboard.
Remove the plug in the front of the lcd screen plug.
Remove the LCD screen plug last. For reassembly, follow the instructions in reverse order, replacing the old motherboard with the new one to fix the power auxiliary port.
