Ga door naar hoofdinhoud
Insignia NS-B4111 Motherboard Replacement
Wat je nodig hebt
  1. Insignia NS-B4111 Motherboard Replacement, Battery: stap 1, afbeelding 1 van 2 Insignia NS-B4111 Motherboard Replacement, Battery: stap 1, afbeelding 2 van 2
    • Unplug and remove the power cord. Turn the boombox upside down.
    • Grip the sides of the case and use your thumbs to pop open the battery cover.
  2. Insignia NS-B4111 Motherboard Replacement: stap 2, afbeelding 1 van 2 Insignia NS-B4111 Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Pry out the batteries with your fingers.
  3. Insignia NS-B4111 Motherboard Replacement, Casing: stap 3, afbeelding 1 van 1
    • Turn the boombox upside down again. With the Phillips PH1 or the Flathead #3 screwdriver, remove the three 14mm black screws.
    • Remove the four 18mm chrome screws with the Phillips PH1 screwdriver.
  4. Insignia NS-B4111 Motherboard Replacement: stap 4, afbeelding 1 van 2 Insignia NS-B4111 Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Gently remove the bottom half of the casing from the top half of the casing.
    • The antenna base is connected to the motherboard by a red wire. This wire will prevent the two halves from separating completely.
  5. Insignia NS-B4111 Motherboard Replacement, Antenna Base: stap 5, afbeelding 1 van 2 Insignia NS-B4111 Motherboard Replacement, Antenna Base: stap 5, afbeelding 2 van 2
    • Remove the 10mm chrome screw from the antenna base with the Phillips PH1 screwdriver. Remove the antenna base from the casing.
    • This red wire will now be loose and you can move it out of the antenna base slot.
  6. Insignia NS-B4111 Motherboard Replacement, Motherboard: stap 6, afbeelding 1 van 1
    • Unscrew the four 12.5mm screws with the Phillips PH1 Screwdriver.
    • Unscrew the one 10mm long screw with the Phillips PH1 Screwdriver.
  7. Insignia NS-B4111 Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Orient the device so that the back is facing you.
    • Unplug the six pin male/female header from its socket on the motherboard. The wires on the header are these colors: burgundy, red, orange, yellow, green, and blue.
    • Use a tweezer if you find it hard to pull the header out with your fingers.
    • Gently pull out the ribbon cable from its socket on the motherboard.
    • Pay attention to the orientation of the header and the ribbon cable. Replacing the wires the wrong way may short circuit the board.
  8. Insignia NS-B4111 Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Rotate the device so that the front is facing you.
    • Unplug the four pin header from its socket on the motherboard. The wires on the header are these colors: brown, red, orange, and yellow.
    • Use a tweezer if you find it hard to pull this header out with your fingers.
    • Gently pull out the ribbon cable from its socket.
    • Pay attention to the orientation of the header and the ribbon cable. Replacing the base the wrong way may short circuit the board.
  9. Insignia NS-B4111 Motherboard Replacement: stap 9, afbeelding 1 van 1
    • Pull out the two pin header from its socket on the motherboard. The wires on this header are black and white.
    • Use a tweezer if you find it hard to pull this cable out with your fingers.
  10. Insignia NS-B4111 Motherboard Replacement, Motherboard: stap 10, afbeelding 1 van 1
    • Scrape off the glue from the black wire with the blue plastic opening tool.
  11. Insignia NS-B4111 Motherboard Replacement: stap 11, afbeelding 1 van 2 Insignia NS-B4111 Motherboard Replacement: stap 11, afbeelding 2 van 2
    • Desolder the one black, one red, and two blue wires. If you need help soldering, see this guide.
Conclusie
Kristin Yoshioka
984 Reputatie
9 handleidingen geschreven
UC Davis, Team 1-5, Oliver Fall 2016 Lid van UC Davis, Team 1-5, Oliver Fall 2016
UCD-OLIVER-F16S1G5
5 Leden
11 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 17
Altijd: 1,102
