Ga door naar hoofdinhoud
Insignia NS-15MS0832B Battery Replacement
Wat je nodig hebt
  1. Insignia NS-15MS0832B Battery  Replacement, Battery: stap 1, afbeelding 1 van 1
    • Begin the replacement for the battery by opening up the device with a plastic opening tool along the edge.
    • Work the plastic opening tool along the edge until you have separated the screen from the back plate.
  2. Insignia NS-15MS0832B Battery  Replacement: stap 2, afbeelding 1 van 1
    • Your tablet should look like this once separated.
  3. Insignia NS-15MS0832B Battery  Replacement: stap 3, afbeelding 1 van 1
    • Start by placing tablet face down and carefully removing the mesh wire tap from the back of the battery.
  4. Insignia NS-15MS0832B Battery  Replacement: stap 4, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Remove the flat wire from its connector with the tweezers and fold to the side so that it's clear of the battery.
  5. Insignia NS-15MS0832B Battery  Replacement: stap 5, afbeelding 1 van 1
    • Next locate where the battery has three wires attached to the mother board. Take out the soldering iron and begin heating it up.
    • Check out iFixit's How to Solder and Desolder Connections guide for soldering help.
  6. Insignia NS-15MS0832B Battery  Replacement: stap 6, afbeelding 1 van 1
    • Once the soldering iron has heated up, begin by placing the tip of the iron where the wire directly meets the mother board. The soldering should heat up and allow you to gently pull the wire off. Repeat twice more to remove each of the three wires.
  7. Insignia NS-15MS0832B Battery  Replacement: stap 7, afbeelding 1 van 1
    • Once all wires have been removed from mother board, take plastic opening tool and separate the battery from the back of the screen. Its connected with glue, so don't worry.
  8. Insignia NS-15MS0832B Battery  Replacement: stap 8, afbeelding 1 van 1
    • Remove battery and replace faulty one with new battery.
Conclusie
To reassemble your Insignia W-Fi Windows 8" Tablet, follow these instructions in reverse order.
Één andere persoon heeft deze handleiding voltooid.
Harrison Smith
329 Reputatie
3 handleidingen geschreven
Texas Tech, Team 1-1, Bennett Fall 2016 Lid van Texas Tech, Team 1-1, Bennett Fall 2016
TTU-BENNETT-F16S1G1
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 12
Altijd: 1,165
