Ga door naar hoofdinhoud
Insignia Flex 8 Screen Replacement
Wat je nodig hebt
    1. Insignia Flex 8 Screen Replacement, Circuit Board: stap 1, afbeelding 1 van 1
      • Turn off the power to your tablet to avoid injury.
      • Position the tablet so that the screen is face down and the power button is located in the upper left hand corner.
      • Hold down the power button for five seconds until the tablet powers down.
      Vraag FixBot
      Voeg opmerking toe
    2. Insignia Flex 8 Screen Replacement: stap 2, afbeelding 1 van 2 Insignia Flex 8 Screen Replacement: stap 2, afbeelding 2 van 2
      • Remove the back casing from the screen by sliding a credit card or a similarly thin but firm object in between the casing and the screen.
      • You may need to use a spudger to initially create separation between the screen and the casing.
      • Run this object around the perimeter of the tablet until there is separation between the casing and the screen.
      • Remove the back casing and set aside.
      Vraag FixBot
      Voeg opmerking toe
    3. Insignia Flex 8 Screen Replacement: stap 3, afbeelding 1 van 2 Insignia Flex 8 Screen Replacement: stap 3, afbeelding 2 van 2
      • Peel tape off of ribbon connectors. Starting at the power button, work clockwise around the tablet.
      Vraag FixBot
      Voeg opmerking toe
    4. Insignia Flex 8 Screen Replacement: stap 4, afbeelding 1 van 3 Insignia Flex 8 Screen Replacement: stap 4, afbeelding 2 van 3 Insignia Flex 8 Screen Replacement: stap 4, afbeelding 3 van 3
      • To remove the camera ribbon cable, lift the flap using a spudger.
      • Pull the ribbon directly back to release it.
      Vraag FixBot
      Voeg opmerking toe
    5. Insignia Flex 8 Screen Replacement: stap 5, afbeelding 1 van 3 Insignia Flex 8 Screen Replacement: stap 5, afbeelding 2 van 3 Insignia Flex 8 Screen Replacement: stap 5, afbeelding 3 van 3
      • Remove the second ribbon cable by prying up the black flap using a spudger.
      • Pull the ribbon cable horizontally directly away from the battery.
      Vraag FixBot
      Voeg opmerking toe
    6. Insignia Flex 8 Screen Replacement: stap 6, afbeelding 1 van 3 Insignia Flex 8 Screen Replacement: stap 6, afbeelding 2 van 3 Insignia Flex 8 Screen Replacement: stap 6, afbeelding 3 van 3
      • Remove the final ribbon cable by pulling back the two black tabs on either side of the ribbon cable.
      • Pull the ribbon horizontally directly away from the battery.
      Vraag FixBot
      Voeg opmerking toe
    7. Insignia Flex 8 Screen Replacement: stap 7, afbeelding 1 van 2 Insignia Flex 8 Screen Replacement: stap 7, afbeelding 2 van 2
      • Unscrew the thirteen 4.75mm screws around the perimeter of the tablet using a PH 00 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    8. Insignia Flex 8 Screen Replacement: stap 8, afbeelding 1 van 2 Insignia Flex 8 Screen Replacement: stap 8, afbeelding 2 van 2
      • Unscrew the four 3.75mm screws and plastic washers using a PH 00 screwdriver.
      • Lift up the circuit board.
      Vraag FixBot
      Voeg opmerking toe
    9. Insignia Flex 8 Screen Replacement: stap 9, afbeelding 1 van 1
      • Unscrew the final two screws that were underneath the circuit board.
      • These screws are near the charging port and USB adapter.
      • These screws are also 3.75mm and can be interchanged with the second set of screws only.
      Vraag FixBot
      Voeg opmerking toe
    10. Insignia Flex 8 Screen Replacement: stap 10, afbeelding 1 van 1
      • Lift the circuit board and black internal mounting piece away from the screen.
      • Set the circuit board aside.
      • Be careful of the soldered antenna as you separate the pieces.
      • Be careful of the soldered ribbon that is connected to the power source. This ribbon is fragile.
      Vraag FixBot
      Voeg opmerking toe
    1. Insignia Flex 8 Screen Replacement, Screen: stap 11, afbeelding 1 van 1
      • Slide the spudger in between the silver screen and the black border
      Vraag FixBot
      Voeg opmerking toe
    2. Insignia Flex 8 Screen Replacement: stap 12, afbeelding 1 van 1
      • Pry up the LCD display and lift it away from the plastic screen.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
5 andere personen hebben deze handleiding voltooid.
Tyler Tyrrell
890 Reputatie
4 handleidingen geschreven
Colorado Springs, Team 5-5, Panko Spring 2015 Lid van Colorado Springs, Team 5-5, Panko Spring 2015
UCCS-PANKO-S15S5G5
3 Leden
12 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 43
Altijd: 8,673
