Ga door naar hoofdinhoud
Insignia Flex 8 Antenna Replacement
Wat je nodig hebt
  1. Insignia Flex 8 Antenna Replacement, Circuit Board: stap 1, afbeelding 1 van 1
    • Turn off the power to your tablet to avoid injury.
    • Position the tablet so that the screen is face down and the power button is located in the upper left hand corner.
    • Hold down the power button for five seconds until the tablet powers down.
  2. Insignia Flex 8 Antenna Replacement: stap 2, afbeelding 1 van 2 Insignia Flex 8 Antenna Replacement: stap 2, afbeelding 2 van 2
    • Remove the back casing from the screen by sliding a credit card or a similarly thin but firm object in between the casing and the screen.
    • You may need to use a spudger to initially create separation between the screen and the casing.
    • Run this object around the perimeter of the tablet until there is separation between the casing and the screen.
    • Remove the back casing and set aside.
  3. Insignia Flex 8 Antenna Replacement: stap 3, afbeelding 1 van 2 Insignia Flex 8 Antenna Replacement: stap 3, afbeelding 2 van 2
    • Peel tape off of ribbon connectors. Starting at the power button, work clockwise around the tablet.
  4. Insignia Flex 8 Antenna Replacement: stap 4, afbeelding 1 van 3 Insignia Flex 8 Antenna Replacement: stap 4, afbeelding 2 van 3 Insignia Flex 8 Antenna Replacement: stap 4, afbeelding 3 van 3
    • To remove the camera ribbon cable, lift the flap using a spudger.
    • Pull the ribbon directly back to release it.
  5. Insignia Flex 8 Antenna Replacement: stap 5, afbeelding 1 van 3 Insignia Flex 8 Antenna Replacement: stap 5, afbeelding 2 van 3 Insignia Flex 8 Antenna Replacement: stap 5, afbeelding 3 van 3
    • Remove the second ribbon cable by prying up the black flap using a spudger.
    • Pull the ribbon cable horizontally directly away from the battery.
  6. Insignia Flex 8 Antenna Replacement: stap 6, afbeelding 1 van 3 Insignia Flex 8 Antenna Replacement: stap 6, afbeelding 2 van 3 Insignia Flex 8 Antenna Replacement: stap 6, afbeelding 3 van 3
    • Remove the final ribbon cable by pulling back the two black tabs on either side of the ribbon cable.
    • Pull the ribbon horizontally directly away from the battery.
  7. Insignia Flex 8 Antenna Replacement: stap 7, afbeelding 1 van 2 Insignia Flex 8 Antenna Replacement: stap 7, afbeelding 2 van 2
    • Unscrew the thirteen 4.75mm screws around the perimeter of the tablet using a PH 00 screwdriver.
  8. Insignia Flex 8 Antenna Replacement: stap 8, afbeelding 1 van 2 Insignia Flex 8 Antenna Replacement: stap 8, afbeelding 2 van 2
    • Unscrew the four 3.75mm screws and plastic washers using a PH 00 screwdriver.
    • Lift up the circuit board.
  9. Insignia Flex 8 Antenna Replacement: stap 9, afbeelding 1 van 1
    • Unscrew the final two screws that were underneath the circuit board.
    • These screws are near the charging port and USB adapter.
    • These screws are also 3.75mm and can be interchanged with the second set of screws only.
  10. Insignia Flex 8 Antenna Replacement: stap 10, afbeelding 1 van 1
    • Lift the circuit board and black internal mounting piece away from the screen.
    • Set the circuit board aside.
    • Be careful of the soldered antenna as you separate the pieces.
    • Be careful of the soldered ribbon that is connected to the power source. This ribbon is fragile.
  11. Insignia Flex 8 Antenna Replacement, Antenna: stap 11, afbeelding 1 van 1
    • Pry black antenna unit away from the back of the screen.
  12. Insignia Flex 8 Antenna Replacement: stap 12, afbeelding 1 van 1
    • Remove tape from attached wire.
  13. Insignia Flex 8 Antenna Replacement: stap 13, afbeelding 1 van 1
    • Desolder antenna wire from circuit board.
    • Desoldering Guide
    • Use caution when using the soldering gun. DO NOT touch any of the other components on the circuit board or the battery.
Conclusie
Grace Gerke
213 Reputatie
2 handleidingen geschreven
Colorado Springs, Team 5-5, Panko Spring 2015 Lid van Colorado Springs, Team 5-5, Panko Spring 2015
UCCS-PANKO-S15S5G5
3 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 1,054
