Inleiding
This guide will provide you with step by step instructions on how to replace the speakers inside the device. This replacement should only be required for faulty speakers.
Wat je nodig hebt
Gereedschap gebruikt in deze stap:Plastic Cards$2.99
Using a plastic tool and the plastic card, gently pry off the back cover.
Gereedschap gebruikt in deze stap:Tweezers$4.99
Remove 2 electrical connectors that connects to the speaker using flat tweezers.
Bijna klaar!
Conclusie
