Inleiding
If your tablet will not turn on even after charging, you may need to replace the battery. Be careful not to severely bend or puncture the battery when you are removing it as it may leak potentially dangerous chemicals.
Wat je nodig hebt
Position the tablet with the top edge by the camera facing down.
Insert the plastic opening tool between the front panel and back case at the upper left hand corner of the tablet.
Using the plastic opening tool, lift up the black retaining flap that secures the ZIF (zero insertion force) ribbon connector over the battery to the motherboard.
The battery is now free rom the device and can be replaced. To reassemble your device, follow these instructions in reverse order.
6 andere personen hebben deze handleiding voltooid.
4 opmerkingen
great instructions....congratulations...i was able to replace the battery in 10 minutes
I have an Insignia tablet and the battery is gone and I need to find out how much a battery will be. if it will be worth getting one or replacing the tablet
please let me know what I need to do you can email me at clarklinda10@yahoo.com
Necesito el software del la tablet insignia ns14t004, o un software parecido a insignia 10.1.
Por favor, mi correo es adair.saenz01@gmail.com
If possible, the battery should be discharged as far as possible to reduce the chance of explosion if the lines are accidentally shorted while de-soldering the lines from the mainboard.
