Ga door naar hoofdinhoud
Innioasis Y1 SD Card Replacement
Wat je nodig hebt
  1. Innioasis Y1 SD Card Replacement, Open The Case: stap 1, afbeelding 1 van 3 Innioasis Y1 SD Card Replacement, Open The Case: stap 1, afbeelding 2 van 3 Innioasis Y1 SD Card Replacement, Open The Case: stap 1, afbeelding 3 van 3
    • Use a pry tool and start half way up the left or right side of the MP3 player, working your way around the edge
    • Carefully lift the cover off and detach the connecting cable
  2. Innioasis Y1 SD Card Replacement, Remove the Main Board: stap 2, afbeelding 1 van 3 Innioasis Y1 SD Card Replacement, Remove the Main Board: stap 2, afbeelding 2 van 3 Innioasis Y1 SD Card Replacement, Remove the Main Board: stap 2, afbeelding 3 van 3
    • Remove the 3 screws with a Philips #00
    • Carefully remove the Speak from its clasps with a pry tool
    • Carefully lift the board on the left side with the pry tool
  3. Innioasis Y1 SD Card Replacement, Flip the Board: stap 3, afbeelding 1 van 3 Innioasis Y1 SD Card Replacement, Flip the Board: stap 3, afbeelding 2 van 3 Innioasis Y1 SD Card Replacement, Flip the Board: stap 3, afbeelding 3 van 3
    • Carefully Lift the board up and towards the screen. You may need to lightly pry the battery out of its socket
    • Remove the tape
    • Slide the Micro SD card out of the socket
Conclusie
3 andere personen hebben deze handleiding voltooid.
Dan
4.433 Reputatie
9 handleidingen geschreven
4 opmerkingen
Tired of waiting for a reaction to my questions above I bought a Samsung 512GB Micro SD Evo Plus UHS-I U3 SDcard. Maybe overkill, but very fast. the replacement of the card was a 5 minutes job. Now I am copying the contents of the old 128GB card to the Innioasis Y3 which will take hours I guess. I let everyone know if it all works fine.
P. Reuvers - Antwoord
It works great. Only one small issue. The Innioasis Y1 shows that it contain 128GB, But he shows the correct used and available space, at this moment I used 143GB of the 512GB, more then the original Innioasis Y1.
P. Reuvers -
Any suggestion on how to format the SD Card? thanks
Paninaro -
Will this work with an ExFAT format card or just FAT32? Thanks
jjedwards894 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 69
Afgelopen 30 dagen: 264
Altijd: 3,403
