Ga door naar hoofdinhoud
Infant Optics DXR-8 Battery Replacement
    1. Infant Optics DXR-8 Battery  Replacement, Battery: stap 1, afbeelding 1 van 3 Infant Optics DXR-8 Battery  Replacement, Battery: stap 1, afbeelding 2 van 3 Infant Optics DXR-8 Battery  Replacement, Battery: stap 1, afbeelding 3 van 3
      • Begin by holding the Monitor so that the backside is flipped up. This is where your battery is located.
      • Slide the battery panel downwards to detach it completely. The battery should be completely visible.
      Vraag FixBot
      Voeg opmerking toe
    2. Infant Optics DXR-8 Battery  Replacement: stap 2, afbeelding 1 van 3 Infant Optics DXR-8 Battery  Replacement: stap 2, afbeelding 2 van 3 Infant Optics DXR-8 Battery  Replacement: stap 2, afbeelding 3 van 3
      • Now that your battery is exposed, begin to take the battery out. The only thing keeping the battery in the battery port should be the plug.
      • Now unplug the battery from the battery port. The plug is small so be careful locating it.
      • The battery and plug should be completely out of the battery port.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
To reassemble your device, follow these instructions in reverse order
4 andere personen hebben deze handleiding voltooid.
Katelynn Dinius
269 Reputatie
1 Handleiding geschreven
Cal Poly, Team 13-4, Banghart Winter 2017 Lid van Cal Poly, Team 13-4, Banghart Winter 2017
CPSU-BANGHART-W17S13G4
4 Leden
24 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 61
Altijd: 12,561
