Ga door naar hoofdinhoud
InFocus Screenplay 4805 Motherboard Replacement
Wat je nodig hebt
  1. InFocus Screenplay 4805 Motherboard Replacement, Top Panel: stap 1, afbeelding 1 van 3 InFocus Screenplay 4805 Motherboard Replacement, Top Panel: stap 1, afbeelding 2 van 3 InFocus Screenplay 4805 Motherboard Replacement, Top Panel: stap 1, afbeelding 3 van 3
    • Flip the projector on its back.
    • Use the Phillips #2 screwdriver to remove the (4) four 2 cm gold screws.
    • Use the Phillips #2 screwdriver to remove the (3) three 1 cm silver screws.
    Vraag FixBot
    Voeg opmerking toe
  2. InFocus Screenplay 4805 Motherboard Replacement: stap 2, afbeelding 1 van 2 InFocus Screenplay 4805 Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Turn the projector, facing the back cable board towards you.
    • Using the Phillips #0 screwdriver, remove the (3) three 1.0 cm silver screws on the back panel.
    • Gently take off back cable panel.
    Vraag FixBot
    Voeg opmerking toe
  3. InFocus Screenplay 4805 Motherboard Replacement: stap 3, afbeelding 1 van 3 InFocus Screenplay 4805 Motherboard Replacement: stap 3, afbeelding 2 van 3 InFocus Screenplay 4805 Motherboard Replacement: stap 3, afbeelding 3 van 3
    • Turn the projector so the front side with the lens is facing you.
    • Gently pry the both of the grey lens rings using the metal spudger.
    Vraag FixBot
    Voeg opmerking toe
  4. InFocus Screenplay 4805 Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Now that the screws have been removed, proceed with the removal of the outer panel.
    • Gently remove the front lens panel.
    • Be forewarned, the panel will resist. Be careful not to break the lens.
    Vraag FixBot
    Voeg opmerking toe
  5. InFocus Screenplay 4805 Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Being careful not to pull the wires inside the projector, gently lift the top panel off the projector.
    • Rest the lid behind the projector so the insides are exposed and undamaged.
    Vraag FixBot
    Voeg opmerking toe
  6. InFocus Screenplay 4805 Motherboard Replacement, Motherboard: stap 6, afbeelding 1 van 3 InFocus Screenplay 4805 Motherboard Replacement, Motherboard: stap 6, afbeelding 2 van 3 InFocus Screenplay 4805 Motherboard Replacement, Motherboard: stap 6, afbeelding 3 van 3
    • Using the Phillips #1 screwdriver, remove the (4) four 1.5 cm screws on each of the four corners of the motherboard cover.
    • Remove the white tab connected to the light bulb.
    Vraag FixBot
    Voeg opmerking toe
  7. InFocus Screenplay 4805 Motherboard Replacement: stap 7, afbeelding 1 van 3 InFocus Screenplay 4805 Motherboard Replacement: stap 7, afbeelding 2 van 3 InFocus Screenplay 4805 Motherboard Replacement: stap 7, afbeelding 3 van 3
    • Gently pull the white tab on the right side of the silver power housing by pinching each side of it.
    • Pinch the two black tabs on the inside of the cover to remove.
    • Gently pull on the long white tab to remove it.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 18
Altijd: 670
