Ga door naar hoofdinhoud
InFocus Screenplay 4805 Lamp Rebuild
Wat je nodig hebt
  1. InFocus Screenplay 4805 Lamp Rebuild, **REBUILD ONLY** Housing disassembly: stap 1, afbeelding 1 van 2 InFocus Screenplay 4805 Lamp Rebuild, **REBUILD ONLY** Housing disassembly: stap 1, afbeelding 2 van 2
    • This guide assumes tht you have removed the lamp unit from the projector. If you have not, refer to this guide first: InFocus Screenplay 4805 Lamp Replacement
    • Slide the bulb housing out of the projector.
    • Use the Phillips #1 screwdriver to remove the three 1 cm gold screws on the bulb housing.
    Vraag FixBot
    Voeg opmerking toe
  2. InFocus Screenplay 4805 Lamp Rebuild, **REBUILD ONLY** Housing disassembly: stap 2, afbeelding 1 van 2 InFocus Screenplay 4805 Lamp Rebuild, **REBUILD ONLY** Housing disassembly: stap 2, afbeelding 2 van 2
    • This step is only required when rebuilding the old lamp with a replacement bulb.
    • Gently pull the top of the bulb housing off.
    • Lift up the middle of the bulb housing to remove it.
    • Be careful of loose parts, such as the metal housing and the glass focusing lens.
    Vraag FixBot
    Voeg opmerking toe
  3. InFocus Screenplay 4805 Lamp Rebuild, **REBUILD ONLY** Housing disassembly: stap 3, afbeelding 1 van 3 InFocus Screenplay 4805 Lamp Rebuild, **REBUILD ONLY** Housing disassembly: stap 3, afbeelding 2 van 3 InFocus Screenplay 4805 Lamp Rebuild, **REBUILD ONLY** Housing disassembly: stap 3, afbeelding 3 van 3
    • Unhook the spring from the bulb housing.
    • Gently remove the bulb.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
To reassemble the device, follow these instructions in reverse order.
Marilyn Urness
671 Reputatie
7 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 12
Altijd: 154
