Ga door naar hoofdinhoud
InFocus LP540 Projector Main Fans Replacement
Wat je nodig hebt
  1. InFocus LP540 Projector Main Fans Replacement, Main Board: stap 1, afbeelding 1 van 3 InFocus LP540 Projector Main Fans Replacement, Main Board: stap 1, afbeelding 2 van 3 InFocus LP540 Projector Main Fans Replacement, Main Board: stap 1, afbeelding 3 van 3
    • Flip the projector right-side up and turn it so that the back ports are facing you.
    • Remove the 7 mm metallic screws using the flat-head screwdriver.
    • Using the T10 Torx screwdriver, remove the two black 10 mm screws located at the center of the back panel.
    Vraag FixBot
    Voeg opmerking toe
  2. InFocus LP540 Projector Main Fans Replacement: stap 2, afbeelding 1 van 2 InFocus LP540 Projector Main Fans Replacement: stap 2, afbeelding 2 van 2
    • Flip the projector over.
    • Use the T10 Torx screwdriver head to remove the two 77mm screws located nearest to the back panel ports.
    • Remove the two 10mm screws located near the lens side with the T10 Torx screwdriver head.
    • Flip the projector back over.
    • Lift up the main lid cautiously to avoid ripping the electrical ribbons.
    Vraag FixBot
    Voeg opmerking toe
  3. InFocus LP540 Projector Main Fans Replacement: stap 3, afbeelding 1 van 3 InFocus LP540 Projector Main Fans Replacement: stap 3, afbeelding 2 van 3 InFocus LP540 Projector Main Fans Replacement: stap 3, afbeelding 3 van 3
    • Unplug the speaker wire from the circuit board by simultaneously squeezing the sides and pulling.
    • Pull on the brown tabs located at the sides of the white plastic ribbon holder and pull the ribbon out.
    • Remove the top cover.
    Vraag FixBot
    Voeg opmerking toe
  4. InFocus LP540 Projector Main Fans Replacement: stap 4, afbeelding 1 van 2 InFocus LP540 Projector Main Fans Replacement: stap 4, afbeelding 2 van 2
    • Hold down the release tabs to remove the cables from the white tabs.
    Vraag FixBot
    Voeg opmerking toe
  5. InFocus LP540 Projector Main Fans Replacement: stap 5, afbeelding 1 van 3 InFocus LP540 Projector Main Fans Replacement: stap 5, afbeelding 2 van 3 InFocus LP540 Projector Main Fans Replacement: stap 5, afbeelding 3 van 3
    • Use the T10 Torx screwdriver to remove the five 5mm screws located throughout the motherboard.
    • Pull up the five metal tabs located at the rear of the projector.
    • Do not pull up on the metal tabs too hard or too fast because they can break easily.
    Vraag FixBot
    Voeg opmerking toe
  6. InFocus LP540 Projector Main Fans Replacement: stap 6, afbeelding 1 van 3 InFocus LP540 Projector Main Fans Replacement: stap 6, afbeelding 2 van 3 InFocus LP540 Projector Main Fans Replacement: stap 6, afbeelding 3 van 3
    • Remove the three gold ribbons by flipping up the black taps that hold the ribbon in place.
    • Pull the ribbons out carefully and place them under the main board.
    • Carefully lift the entire main board up.
    Vraag FixBot
    Voeg opmerking toe
  7. InFocus LP540 Projector Main Fans Replacement, Main Fans: stap 7, afbeelding 1 van 2 InFocus LP540 Projector Main Fans Replacement, Main Fans: stap 7, afbeelding 2 van 2
    • Once the main board has been removed, carefully lift the fans upward. Make sure no cables are tangled in the process.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jorge L Navarro
533 Reputatie
5 handleidingen geschreven
Cal Poly, Team 13-17, Regan Winter 2014 Lid van Cal Poly, Team 13-17, Regan Winter 2014
CPSU-REGAN-W14S13G17
6 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 25
Altijd: 1,763
