Ga door naar hoofdinhoud
InFocus IN3104 Color Wheel Replacement
Wat je nodig hebt
  1. InFocus IN3104 Color Wheel Replacement, Top Cover: stap 1, afbeelding 1 van 3 InFocus IN3104 Color Wheel Replacement, Top Cover: stap 1, afbeelding 2 van 3 InFocus IN3104 Color Wheel Replacement, Top Cover: stap 1, afbeelding 3 van 3
    • Turn the projector so that the lens is facing you.
    • On the left side of the projector, there is a screw and a knob inside of the small grate.
    • Use a Phillips #1 screwdriver to remove the 6 mm screw that secures top cover.
    • Remove the service cover.
    Vraag FixBot
    Voeg opmerking toe
  2. InFocus IN3104 Color Wheel Replacement: stap 2, afbeelding 1 van 3 InFocus IN3104 Color Wheel Replacement: stap 2, afbeelding 2 van 3 InFocus IN3104 Color Wheel Replacement: stap 2, afbeelding 3 van 3
    • Use a Phillips #1 screwdriver to remove the seven 6 mm screws.
    • Use a Phillips #1 screwdriver to remove the two 5 mm screws.
    • Remove the top cover.
    • Do not pull the cover too hard. It may damage the wire that is connected to the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  3. InFocus IN3104 Color Wheel Replacement, InFocus IN3104 Metal Cover Disassembly: stap 3, afbeelding 1 van 2 InFocus IN3104 Color Wheel Replacement, InFocus IN3104 Metal Cover Disassembly: stap 3, afbeelding 2 van 2
    • Use a Phillips #1 screwdriver to remove the nine 6 mm screws.
    • Lift up the metal cover and set it aside to reveal the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  4. InFocus IN3104 Color Wheel Replacement: stap 4, afbeelding 1 van 3 InFocus IN3104 Color Wheel Replacement: stap 4, afbeelding 2 van 3 InFocus IN3104 Color Wheel Replacement: stap 4, afbeelding 3 van 3
    • Carefully pry up the black plastic locking bar of the ZIF connector on the motherboard with a plastic spudger.
    • Pull out the blue-tipped, white ribbon cable from the connector.
    • Remove the metal cover.
    Vraag FixBot
    Voeg opmerking toe
  5. InFocus IN3104 Color Wheel Replacement, Color Wheel: stap 5, afbeelding 1 van 3 InFocus IN3104 Color Wheel Replacement, Color Wheel: stap 5, afbeelding 2 van 3 InFocus IN3104 Color Wheel Replacement, Color Wheel: stap 5, afbeelding 3 van 3
    • Unplug two cables from the edge of the motherboard labeled 80.87 MO and KYO.
    Vraag FixBot
    Voeg opmerking toe
  6. InFocus IN3104 Color Wheel Replacement: stap 6, afbeelding 1 van 2 InFocus IN3104 Color Wheel Replacement: stap 6, afbeelding 2 van 2
    • Carefully lift up the black paper cover. Do not completely remove it from the device.
    • Lift the paper cover up to reveal two 6mm screws.
    Vraag FixBot
    Voeg opmerking toe
  7. InFocus IN3104 Color Wheel Replacement: stap 7, afbeelding 1 van 2 InFocus IN3104 Color Wheel Replacement: stap 7, afbeelding 2 van 2
    • Use a Phillips #1 screwdriver to remove the two 6mm screws.
    • Remove the color wheel from the device by lifting it out of the projector.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 31
Altijd: 835
