Ga door naar hoofdinhoud
Linksys WRT54GS v2 Antenna Ports Replacement
Wat je nodig hebt
  1. Linksys WRT54GS v2 Antenna Ports Replacement, Front Case: stap 1, afbeelding 1 van 1
    • Turn the router over so that all four of its feet are facing upwards.
  2. Linksys WRT54GS v2 Antenna Ports Replacement: stap 2, afbeelding 1 van 1
    • Remove the rubber inserts inside the the two purple feet located on the router's front case.
    • This may be a challenge, so try the following two methods:
    • Use a plastic opening tool. Insert the flat end of the tool into the seam and slowly pry the rubber feet out.
    • Use a metal spudger. Insert the point of the metal spudger directly into the hole of the rubber feet and pry the insert out.
  3. Linksys WRT54GS v2 Antenna Ports Replacement: stap 3, afbeelding 1 van 1
    • Use a Phillips #2 Screwdriver to remove the two 5.8 mm screws holding the front case to the motherboard.
  4. Linksys WRT54GS v2 Antenna Ports Replacement: stap 4, afbeelding 1 van 1
    • Squeeze the sides of the router's backcase inward and pull off the purple front case. It is helpful to have a second person assist you for this step.
  5. Linksys WRT54GS v2 Antenna Ports Replacement, Motherboard: stap 5, afbeelding 1 van 1
    • Slide the board unit out and up.
  6. Linksys WRT54GS v2 Antenna Ports Replacement: stap 6, afbeelding 1 van 1
    • Flip the circuit board over and use a Phillips #2 Screwdriver to remove the 6.9mm screw holding the board to the back case.
    • Slide the back cover out and away from the circuit board.
  7. Linksys WRT54GS v2 Antenna Ports Replacement, Antenna Ports: stap 7, afbeelding 1 van 2 Linksys WRT54GS v2 Antenna Ports Replacement, Antenna Ports: stap 7, afbeelding 2 van 2
    • Turn the circuit board over and identify which solder connection you will desolder.
    • The solder connections shown in red hold the right antenna port in place. There is one more attachment for this antenna on the other side of the board.
    • The solder connections shown in blue hold the left antenna port in place. Desolder these 4 points to remove the antenna port.
  8. Linksys WRT54GS v2 Antenna Ports Replacement: stap 8, afbeelding 1 van 1
    • Turn on your soldering iron and allow it to get to its highest temperature setting (minimum 600ºF).
  9. Linksys WRT54GS v2 Antenna Ports Replacement: stap 9, afbeelding 1 van 1
Conclusie
Allian Roman
276 Reputatie
5 handleidingen geschreven
Cal Poly, Team 3-4, Regan Fall 2011 Lid van Cal Poly, Team 3-4, Regan Fall 2011
CPSU-REGAN-F11S3G4
4 Leden
12 handleidingen geschreven
Één opmerking
Most do not have removeable antennae ports
tom - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 9
Altijd: 3,248
