Ga door naar hoofdinhoud
IdeaPad L340-15API RAM Replacement
Wat je nodig hebt
  1. IdeaPad L340-15API RAM Replacement, Optical Drive: stap 1, afbeelding 1 van 2 IdeaPad L340-15API RAM Replacement, Optical Drive: stap 1, afbeelding 2 van 2
    • Before beginning the repair, make sure that the device is fully powered off.
    • Turn the laptop over so the bottom cover is facing up.
    • The small screw hole near the center of the case, marked with a tiny DVD icon and an arrow, secures the optical drive.
    Vraag FixBot
    Voeg opmerking toe
  2. IdeaPad L340-15API RAM Replacement: stap 2, afbeelding 1 van 2 IdeaPad L340-15API RAM Replacement: stap 2, afbeelding 2 van 2
    • Use a Phillips #1 screwdriver to remove the 7.5 mm screw securing the optical drive.
    • Place the screw down safely in a container/magnet strip where it will not get lost while you are working. These screws are very small and easily misplaced.
    Vraag FixBot
    Voeg opmerking toe
  3. IdeaPad L340-15API RAM Replacement: stap 3, afbeelding 1 van 2 IdeaPad L340-15API RAM Replacement: stap 3, afbeelding 2 van 2
    • Place your thumb at the seam between the optical drive and the device.
    • Gently pull the component straight out from the device, taking care not to pull at an angle.
    Vraag FixBot
    Voeg opmerking toe
  4. IdeaPad L340-15API RAM Replacement, Battery: stap 4, afbeelding 1 van 2 IdeaPad L340-15API RAM Replacement, Battery: stap 4, afbeelding 2 van 2
    • Use a Phillips #1 screwdriver to remove the twelve 7.5 mm screws from the back cover.
    Vraag FixBot
    Voeg opmerking toe
  5. IdeaPad L340-15API RAM Replacement: stap 5, afbeelding 1 van 3 IdeaPad L340-15API RAM Replacement: stap 5, afbeelding 2 van 3 IdeaPad L340-15API RAM Replacement: stap 5, afbeelding 3 van 3
    • Insert a plastic opening pick in the back left corner and wedge the panel open.
    • Slide the pick around the edge of the laptop to release the clips as you lift the panel.
    • If the opening pick isn’t working, use the iFixit opening tool to gain more leverage.
    • Remove the bottom cover.
    Vraag FixBot
    Voeg opmerking toe
  6. IdeaPad L340-15API RAM Replacement: stap 6, afbeelding 1 van 2 IdeaPad L340-15API RAM Replacement: stap 6, afbeelding 2 van 2
    • Use the Phillips #1 screwdriver to remove the five 6.5 mm screws securing the battery.
    • Use a container/magnet strip to store the screws while working.
    Vraag FixBot
    Voeg opmerking toe
  7. IdeaPad L340-15API RAM Replacement: stap 7, afbeelding 1 van 3 IdeaPad L340-15API RAM Replacement: stap 7, afbeelding 2 van 3 IdeaPad L340-15API RAM Replacement: stap 7, afbeelding 3 van 3
    • Use the wide end of a spudger to push the connector tab, sliding the battery connector out of its socket.
    • It may take a lot of force to disconnect the cable. Go slowly, and don't pull on the cables.
    Vraag FixBot
    Voeg opmerking toe
  8. IdeaPad L340-15API RAM Replacement: stap 8, afbeelding 1 van 1
    • Remove the battery from the laptop.
    Vraag FixBot
    Voeg opmerking toe
  9. IdeaPad L340-15API RAM Replacement, RAM: stap 9, afbeelding 1 van 3 IdeaPad L340-15API RAM Replacement, RAM: stap 9, afbeelding 2 van 3 IdeaPad L340-15API RAM Replacement, RAM: stap 9, afbeelding 3 van 3
    • Lift the metal cover next to the heat sink to reveal the RAM.
    Vraag FixBot
    Voeg opmerking toe
  10. IdeaPad L340-15API RAM Replacement: stap 10, afbeelding 1 van 3 IdeaPad L340-15API RAM Replacement: stap 10, afbeelding 2 van 3 IdeaPad L340-15API RAM Replacement: stap 10, afbeelding 3 van 3
    • Using your fingers or a spudger, spread the clips away from the RAM module.
    • Be careful not to pull too hard and damage the metal arms.
    • When released, the RAM module will pop up at a slight angle.
    • Lift the RAM module to an angle of about 30 degrees and slide it out.
    • When handling the RAM module, only touch the outside edges. Take care not to touch the gold-colored contact points along the bottom edge.
    • To install a new RAM module, insert it at about the same angle until it fits securely, then gently press it downward until the clips click into place.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Één andere persoon heeft deze handleiding voltooid.
Jasmyn
205 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 2-5, Bowman Fall 2025 Lid van UMass Dartmouth, Team 2-5, Bowman Fall 2025
UMASSD-BOWMAN-F25S2G5
4 Leden
4 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 21
Altijd: 186
