Ga door naar hoofdinhoud
IQ America VD-8810L Motherboard Replacement
Wat je nodig hebt
  1. IQ America VD-8810L Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 3 IQ America VD-8810L Motherboard Replacement, Motherboard: stap 1, afbeelding 2 van 3 IQ America VD-8810L Motherboard Replacement, Motherboard: stap 1, afbeelding 3 van 3
    • Wedge the spudger into the slot of the panel on the bottom of the device.
    • Rotate out the panel to reveal the screw holding the device together.
  2. IQ America VD-8810L Motherboard Replacement: stap 2, afbeelding 1 van 2 IQ America VD-8810L Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Use the Phillips head screwdriver to remove the screw.
    • Separate the Top and bottom halves of the device.
  3. IQ America VD-8810L Motherboard Replacement: stap 3, afbeelding 1 van 3 IQ America VD-8810L Motherboard Replacement: stap 3, afbeelding 2 van 3 IQ America VD-8810L Motherboard Replacement: stap 3, afbeelding 3 van 3
    • Remove batteries from the battery slot.
    • Unscrew the two Phillips head screws in the center of the battery slot.
    • Unscrew the remaining two screws at the bottom of the unit using the 3.0 triangle head screwdriver.
  4. IQ America VD-8810L Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Use the spudger to separate the top and bottom halves of the screen.
  5. IQ America VD-8810L Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Disconnect the wires from the green motherboard to the bottom half by pulling apart the connecting pins.
  6. IQ America VD-8810L Motherboard Replacement: stap 6, afbeelding 1 van 3 IQ America VD-8810L Motherboard Replacement: stap 6, afbeelding 2 van 3 IQ America VD-8810L Motherboard Replacement: stap 6, afbeelding 3 van 3
    • Unscrew all 3 Phillips head screws on the outside edges of the motherboard.
  7. IQ America VD-8810L Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Carefully remove the microphone from the casing by pulling away from the device.
  8. IQ America VD-8810L Motherboard Replacement: stap 8, afbeelding 1 van 2 IQ America VD-8810L Motherboard Replacement: stap 8, afbeelding 2 van 2
    • Gently lift the motherboard from the casing to reveal the speaker.
    • Unscrew the two Phillips head screws that hold the speaker in place.
  9. IQ America VD-8810L Motherboard Replacement: stap 9, afbeelding 1 van 1
    • Refer to this guide to desolder the speaker from the motherboard.
Conclusie
Jackey Lau
301 Reputatie
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 11
Altijd: 241
